As it seems a few people from the club are going to the Queens Birthday track day organised by circuit club, I would try to make a list of who is going, so we can have an SAU presence there, maybe even head down in a group.
Details for the track day:HERE
I am booked in and am also trying to organise a garage so we have a spot to change wheels and store our stuff.
Please post here or PM if you are confirmed for this day and I will add you to the list.
For those who want to cruise down to Wakefield together, I can meet at Casula Bunnings car park at the cross roads from 6:30am leaving at 6:45am. This is located where the Hume Hwy splits into Camden Valley Way and Campbelltown Road. There is a link to a map on the second page.
I think this is a good spot as it is near the M7 and M5 and it is easy to get on the Freeway and head to Goulburn from this point.
Let me know who wants to meet up from here and PM me if you want my mobile to co ordinate things.
CONFIRMED:
Apollo (Me)
padey
tjandriesen aka "TJ"
scathing
Knockout Ned
https://www.sau.com.au/forums/topic/169631-circuit-club-wakefield-11062007/
  • Replies 92
Yeah I'll be there, along with a few mates.
Unfortunatly my car is only half sorted. I'm still waiting on my new front springs/other suspension bits to arrive and some cam gears and timing belt.
Knowing my luck, they wont arrive. But i'll have a stack of fun anyway.
wish i could make it, but too close to gold coast autosalon and that has sucked up all my money. I really wanted to get down there on some track rubber instead of the crap i used last time, mind you i still managed a 1:14 :thumbsup:
NEWS FLASH FOR THIS EVENT
I have just been informed that Circuit Club is having trouble arranging the timing equipment for this event. The usal company that does the timing is tied up with the V8 supercars.
So it may NOT be a timed track day!!!
I will still be going, I just hope they can arrange an alternative for timing.
Anymore SAU people coming as I need to let them know how many garages we need?
That means we are down to only 3 people from SAU for this event.
Is no one else up for a track day?
I'm a tenantative yes for this one
If I can get my power steering fixed in time I'll head down for a spin! But so far, it's not looking good.
What time do we need to be there?
I'll be taking the M2/M7/M5---->Goulburn.
ap
I'll check but I assume 8:30-9:00 - figure a 2 hour drive that mean we leave Sydney 6:30-7:00?
I'm just north of the bridge so I can either go across thur the city and catch the M5 by the airport or around and catch it M7 down.
I am now a maybe for this event.
Went for a wheel alignment on the weekend and found that something is bent in the rear as I have over 7 degrees of toe in on one of the rear tyres.
Hopefully can find the problem and repair before this day.
If I make it I will be happy to meet up somewhere and drive down as a group.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
