I'm getting a Exedy H/Duty 5-puk cushion button clutch installed in my 33.
Clutch = $460 delivered
Install = $310 inc machine flywheel
Total = $770.
$1100 sounds too much mate?
where did u get that quote for the Exedy H/Duty 5-puk cushion button clutch ?
best i got was 500
Slide
Exedy Cushion Button $439
Installation is available on the Gold Coast for $270 including flywheel machining!!
Sliding Performance
Shop 4/11 Ramly Drive
Burleigh Heads
QLD 4220
I would give Jim Berry a call first
that guy is a legend....
A bit pricey but well worth it.....
Im receiving my full monty :thumbsup: this week including chrome molly flywheel all for $1800 was $2,100 but got he thought it was too expensive so he dropped the price :D
and by the sounds of his clutches well worth the money
fark thats dear, i only paid a bit more and got a full PRO CARBON setup....
