I have a highflowed RB25 comp housing with a highflowed 0P6 ex housing.
It has a new Garrett cartridge,shaft and wheels
What Garrett turbo would this compare with.
It was built by Precision Turbos and is rated at 550hp.
here is the difference between the stock ex housing and the 0P6 one.post-32255-1179911608_thumb.jpg
If they claim its a genuine 550hp
it'll be interesting to see if it gets on the surge train like a few other 550hp hi-flows have before (GCG and others)
Being the wheels are just too big for the rear they become unhappy.
You'll notice the surge regardless of what boost as it will be most prominent in transient response in the lower RPM range where peak boost isnt a factor.
Thats not to say it will of course.
Stick up the wheel specs like Risking said and we can maybe look from there.
Obviously its a T04S wheel by the blades, just what size is the question
Also what size the rear is aswell
ps. i see adrian posting, he knows the most :domokun:
mongrel turbos suffer surge and alot of the early GCG high flows do.
Do you know the actual wheels sizes?? with thme it can easily be matched up with the garrett items
I dont have any specs on the wheels Brad.
Im kicking myself for not getting that info.
My guess is at minimum a GT2876
And max a GT3040
without knowing the inducer and exducer sizes its next to impossible to say. Its depends soely on those sizes.
Bring it around and ill rip the housings off and measure it up.
Like nismoid said its some form of t04S comp wheel so possibly a 52 trim front. I had a bit of info on the common R33 highflows and wheel selecetions somewhere but I cant find it atm.
A quick call to the guys that did it and they should be able to give you wheel part numbers at least even if they dont know the actual dimenssions.
Well the cartridge section appears to be a Garrett ball bearing GT30/T04S but someones machined out the VG30 BB turbine housing and R33 Skylines Hitachi compressor cover to fit .
I don't think Garrett would use those wheels in housings not designed for them so not too sure . The current GCG Hi Flow uses a smaller 7/14 blade compressor with a slightly larger turbine of a different family to the GT30UHP . I don't think I ever saw the higher capacity GCG Hi Flow but if anyone has a pic of one looking at the compressor I'd like to see it .
As to if it will surge ? The only way to know is to try it .
Had it been me I reckon I'd have used the GT2871R 48T BB cartridge like I think Dale FZ1 did because its wheels are a lot closer in size to what the Hitachi housings were designed to work with .
Cheers A .
The cartridge is ball bearing and both housings where machined to the max i think.
Already i can see there must be a few specs of highflows out there.i hope this one isnt a lag monster.
The way to confirm easily is to read the numbers on the ID tag attached to the centre section. If you can, post them up please.
I'm aware of a GT2876 BB cored high flow, using the OP6 housing that performed without surge problems and supported around 250rwkW. Be interested to see if this unit is the same specs.
The difference in that approach to my 2871 48T was in the turbine, with lower gas velocity the compressor was not evidently enough to cause surge issues.
The numbers i got are:
Garrett
JK 0101 J
700177-5017
Hope this helps
Those numbers are really irrelevant with a high flow. you cant be sure of whats in there unless you measure it and check for yourself. Ive seen tagged turbos done by very reputable places that were tagged wrong etc.
I dont think its that large. Ive fitted R33 highflows where the comp housing snout was so thin I was worried about the weight of the clamp crushing the snout!
Personally im not a fan of any high flow turbo unless you have it built a specific spec. For the cost of 3037's etc these days I go with something I can view a comp map of first. Personaly preferance though.
At the end of the day you have had it done so wack it on and find out what its like.
I was told by Precision to be careful with the clamp as exteme force will break it.
Thats just the cartride, generally you wont know what wheels from that.
CHRA = 700177-5017
CHRA = Centre Housing Rotating Assembly
As Risking said, some other wheels could have been slapped on there and you wouldnt even realise.
Ive seen similar things happen myself where the ID tag lists one thing.
But other wheels were substituted and stuck on a different CHRA.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
