How are ya guys. Car is an R32 couple
I have a problem with my central locking. and what it is, is when i lock the car both doors will look but when i unlock the doors only the drivers side will unlock but not the passangers!
Just wondering if anyone can help me out or can point me in the right direction.
Cheers guys, James
https://www.sau.com.au/forums/topic/170007-central-locking/
its not a complete central locking system. as the drivers door locks unlocks, it trips the solenoid which operates the central locking on the passenger door. the problem could be all kinds of things. the best person i reckon to ask would be chris rogers. send him a pm.
https://www.sau.com.au/forums/topic/170007-central-locking/#findComment-3141283
You can lock both, but unlock only does the drivers?
As above the solanoid should lock the passenger side, regardless of whether you are using a remote or doing it by hand. I'd suggest pulling the door skin off the passenger side and checking the rods that connect to the actuator/inner door handle/outside handle, and make sure none of them have slipped.
There are several places you can move an adjuster to kinda "pretension" the rod. More like aligning its throw really. Anyway.. check it if noone has an obvious solution.
https://www.sau.com.au/forums/topic/170007-central-locking/#findComment-3141944
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
