Hey all,
Soooooo, I have an r32 GTR
rb26dett
Garret 2860rs
OS Giken Cam gears
(Now has stainless manifolds, was stock)
Dumps pipes and full exhaust system
HKS pods
PowerFC
Hks AVC-r
It has been off the road for about 2 months, ripped the turbos off, got new manifolds and patched up a couple of holes in the dump pipez. stuck it all back together.
http://www.skylinesaustralia.com/forums/in...p;#entry3032332
(can read about it a bit more there)
Anyhow car is back together now and I easily notice the increase in power and torque.
I have only booted it maybe 2 or 3 times but anytime I do a "Shit Load" of smoke comes spewing out the exhaust, U cant see 10 meters behind you because of the smoke. (Have only done it to that degree once was on 14psi usually just cruise around on 8psi). Before hand there was no smoke at all it was fine just a bit sluggish.
Any thoughts. I checked the oil and it is on low atm (was full 2 weeks ago when car was put back together) I will fill it and watch it closely there is no oil in coolant and so forth. not sure what has happened. The oil pressure gauge dropped down to just above 0 last night as well, (usually in on 4ish at idle, maybe a little below) I thought this might have to do with the amount of oil that was in the car but. Just after some thoughts.
AsH
https://www.sau.com.au/forums/topic/170192-rb26-smoke/
yeah sounds like its burning oil
that would account for the decrease in oil and the smoke
depending on the colour it may not be too bad. The motor may be 'breathing' a little more running more boost on an old engine, therefore you have a bit of oil going through the intake and getting burnt which could create a whitish cloud of smoke
or, the rings may be shot which gives the smoke a bluish tinge.
Have a look at your intake piping to see if theyre coated in oil. If so, a catch can would be a good investment.
If not, get a compression test done firstly, without oil in the cylinder bore and secondly, with a little oil squirted into the cylinder. If compression increases with the oil, then you know that the rings arent the best
But first, tell us what colour smoke you see
https://www.sau.com.au/forums/topic/170192-rb26-smoke/#findComment-3144127
It looks whitish to me not black, dosent look blue, I will have a better look when I go out this afternoon, I did an oil change when I was pulling car apart put some valvoline 5w- 40w stuff in it, supposed to be good for turbo's and so forth could that oil be to thin? if that makes sense?
Edited by AsH__85
https://www.sau.com.au/forums/topic/170192-rb26-smoke/#findComment-3144165
if you took the old turbos off because one was dead, you may have a bore or two with ceramic dust damage.
If not you still might have a very worn pot or two. How many kms has the motor done? Do a compression test is step one anyway.
My bet is low compression/bad ring seal.
You can drive that motor around for a while with your fingers crossed, it will let go one day in the next year.
Sorry to be negative :ermm:
https://www.sau.com.au/forums/topic/170192-rb26-smoke/#findComment-3144275
Little update
Lots of oil in the turbo and intercooler pipes, will get a catch tank asap, engine would be about 80 - 90k old, old turbo's were on last engine, this engine is supposed to of had a good set ripped of when the guys car was written off.
The pressure went back up again today just took if for a little drive then, about 2500rpm was up to about 6kg, on idle was about 2-2.5ish (that is were it was normally sorry wasn't 4). If there is plenty of oil pressure is it still possible the rings are shitted???
I will watch the oil level in the next couple of days and see what its doing and also get that tank and let you know whats happening. One again thanks heaps for all your help and comments guys.
AsH
https://www.sau.com.au/forums/topic/170192-rb26-smoke/#findComment-3144808
UPDATE!!
I hooked up a catch can all smoke is gone, I however there is no oil going into the can at all.
The hose that was going from one rocker cover to the other wasnt standard hose and I think it was kinked, would this cause the oil to be forced through the engine or something along those lines???
Any how its sorted and is running well,
Thanks again for everyones help
AsH
https://www.sau.com.au/forums/topic/170192-rb26-smoke/#findComment-3156730
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
