im basicly gonna update the list as i go through the stuff but heres wat ive got off the top of my head.
Stock R34 GTT ECU
Full Stock Exhaust
stock Double Din Holder
stock neo engine cover
original r34 gtt japanese Cassette/Radio player
original R34 rear and front speakers (Sanyo 6")
these 17x8 rims here (same style diff brand)
these 18x8
thats it for now, ill get prices for the above asap
Edited by R34NRG
https://www.sau.com.au/forums/topic/170207-stock-r34-gtt-parts/
How much for the NEO cover?
$150 inc postage
so u still selling the din pocket or not bro?
yeh still got em going for $80 inc postage
R34 sidemount?
sorry mate rekin got took em off me already
the wheels how much..... got tyres??
sold those rims already with the tyres, but i got a set of these if interested.
18x8 inc falken tyres 80% tred left....good condition. more info soon
will let go for around $1000
Is the ECU still for sale??? Auto or Manual
Manual mate, and yes still for sale
Edited by R34NRG
Is the stock ECU still for sale, what year is your car. How much are you asking. Thanks.
ive been using the stock ECU to clear a few defects lately so its come rather handy, although for the right price i will let it go.
hey whats the condition of the 18's? and whats the offset? they suite r34 gtt?
mint man no probz wat so ever. and yes they do suit the r34.
Edited by R34NRG
  • 1 year later...
  • 5 weeks later...
  • 11 months later...
^^^^ You do realise this thread is like 3 Years old right??? and i don't think Andru is even a member anymore...
Maybe post in the wanted to buy section and see how you go..
Good Luck
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
