I SERIOUSLY doubt you'll find a ball-bearing turbo for under $1500. AFAIK the Highflowed SLIDE turbos are plain-bearing. In fact, I don't know that I've seen ANY ball bearing turbo's around, highflowed, new. or otherwise for under $1500. There's T3/4 hybrids kickin about new for $500 or less, but they're oil-cooled only cores. not too sure on quality or performance either.
hmmmm.. . . . . . .
How does the highflow compare to the std turbo? How noticable is it and how much diff in pwer?
Well mine isn't a slide (I'm sworn to secrecy) but I get the impression it's a similar result in power, lag, efficiency etc. The spool-up below 2,500rpm is possible, but not in the same game as the stockie. Above 3,500rpm tho, it kicks like a frikken Mule ! ! It's definitely not as "ready to go" about town when You're cruisin & give it a prod, but when you've got a few revs onboard to begin with, it's GOLD !
I don't even notice the lag 99% of the time now, just used to it I guess, & automatically adjust/pre-empt.
So its much better than standard (disregarding lag etc)? Both cars I have owned hve been turbo and Ive never upped the boost/changed a turbo before so have never had an idea of how big the increase is.
Lag is not that bad with the standard slide hi-flows, for the small amounts of loss in response there is big time gains in both mid-range and top-end power. Even if you feel it is a bit laggy there are cheap ways of improving response without breaking the bank ie. Retarding ex cam gear, advancing base ignition timing with CAS adjustment, high-flow cats, high flowing mufflers etc.
The power difference is very noticeable, boost hits hard and keeps on pushing rather than plateauing like the standard turbo's do.
Edited by BAMR33
Oh I wouldn't bother with a dead-stock Skyline, I drove a few when I bought mine, and it just ain't no fun !
I'm at about 200rwkw, and I'd say that's just nice for a road car (I've got a fat torque curve tho, 16psi boost midrange, 'til the injectors hit 100% at 5,500rpm) but just barely a starting point for trackwork, IMHO. About 18psi and 250rwkw feels REAL fiesty on the road, I've ridden in one a couple of times, and it'll light up both rears in 2nd, straight-line style. =D
The stockie's restrictive exhaust housing/exducer limits flow to 180rwkw, 190 if you're lucky (or your dyno reads optimistically)
Stock turbo comes on smooth & quick, but ultimately won't set your pants on fire. The real-deal "turbo rush" comes from the laggier, harder-hitting delivery of bigger-flowing turbos.
It's fun :/
1. No frount mount.2.Standard clutch ( when you say my clutch should be replced is this because its going to slip from more power? Or your all just assuming im going to be drifting and doing burnouts?)3.Standard fuel system.4. Piggy back ecu ( IS that what the SAFC does?)
I have a turbo back exhaust (with standard dump pipe),
That's not a 'turbo back' upgrade exhaust.
You'll want to replace the front/dump pipes if yours are standard.
If $$ is an issuea (which it was for me), just get an all in one front/dump 3" from flying performance www.flyn.com.au or something similar.
hmmmm.. . . . . . .
True if you're looking at brand new althought there is/was? a 2nd hand GCG high flow in the for sale in the last few days for $1350 i think and i got my HKS2535 delivered for $1200 from Japan (plus extra expenses on that one though for line etc)
For me, I'd go the 2nd hand GCG over a new Slide but that's just my personal preference.
Yeah Its just the standard dump I have, I have the 3inch Jasma front pipe :/ I will get onto replacing it. Whats better? 2.5Inch split ebay stuff or like a 3 inch single pipe exhaust shop job??
I can never remember which bit is which , front and dump. :/
Do a ring around some zorst places and ask how much to replace that piece then make your own decision.
Yeah will do. Ps dump is right off the turbo front is from dump to cat
  • 2 months later...
Sorry to bring up an old thread guys,
but with this set up - what injectors do you guys use? or what to reccomend?
Ive got the slide hi-flow with other mods like powerFC,EBC, walbro fuel pump
Only thing now that is restricting me is the AFM and injectors
Reccomendations guys?
Cheers,
Chris :)
i have had a slide highflow on my 33 for about 8,000ks now,you can feel more power straight away,but you diffnately need a aftermarket ecu,i have only got the stock computer in at the moment,will put one in soon hopefully,with my car being auto,need to look for a computer that can run the autos well.also will get a high stall,fuel pump etc,but the car and the turbo has good potential to run a low 12sec or even a high 11 second pass,no doubt :P
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
