Hi all,
Have a GTR R33 that is almost complete just waiting on a Greddy 6 speed gearbox that is being built,
It a full Dog Gearbox with straight cut gears etc...i have never had experience with this gearbox so...
My question is....
What is the drivability like ?
The Car wont be driven all that often But are u able to get to A to B without to much hassle?
Basically i want to know if its possible to drive the car 'normally' and change at lower rev's?
Any help at all...
Would be great to hear from people who have had this gearbox
Cheers
tony
You could drive it around normally. However, it will be whiney, noisey and clunky to drive as it is a dog box with straight cut gears. You will also have to change gears more agressively as they tend to need to be smacked in with more force than a normal box. Too slow a change will result in crunching as the gears don't have the softer meshing like helicals have. The difference is akin to upgrading from a stock spring clutch to a multi-plate solid clutch.
Enjoy >_<
PS, rev matching helps
Edited by NXTIME
I had to drive Mark Phillips fully blown drifter round with the dog box and i can tell you it was a piece of piss to live with, the TRUST ones are made by QUAIFE and are super strong except for reverse.... be very gentle with reverse as there were many compromises made to fit a 6spd gear set in a 5spd case.
Thanks to the feedback people : )
Any addition information or experiences feel free to post up..
Oh and I forgot the mention the car is running a brand spanker OS Tripple plate
When selecting reverse do i need to slowly select the gear?
Whats the go?
I had a trust box in my car for quiet sometime driving around on the street.
its alrite once your moving. 1st you need to push hard to get into.
other than that i found it fine! very noisy which i liked!
not the best thing for using to drive but it isnt as bad as made out to be either!
Whats the go?
as said before they focused on making 6 forward gears with the trust/quaife box, so reverse is rather small. and does wear out it will round the corners off the gear which means it wil pop out of gear. (just hold in in reverse and you will have no problems!)
Edited by Angus Smart
Whats the go?
i got a HKS 6 speed dog box. unfortuately i havent fitted yet so i can't give you any personal experience but the guy a brought it of gave me a few pointers.
1. you will have to be aggressive and forceful with it.
2. it is noisy and crunches
3. rev / speed matching helps alot. he spent alot of time watching the tach and speedo when changing
4. if you miss getting a gear you will most likely have to come to a complete stop and start again from first. (not sure why that would be the case)
5. reverse is very fragile. ensure the car is not rolling forward when selecting. If you rolling forward it will go into reverse and even if your just moving forward when you pop the clutch it will break reverse.
I would suggest if you have to park on a slop you park so that you can drive out rather than back out.
On another subject, does anyone know if you can flat change a dog box? I'm going to be running a Bee R style rev limiter for drags which is supposed to enable flat shifting, is this still possible with a dog box.
cheers
cheers
you can clutchless shift and i guess if your going to keep into it you could flatchange too but it may require some clutch assistance
about the missing a gear. it isnt really a problem. its just the same as any other box! you just have to try and select it again.
rev matching your gears is very helpful as you said. i actually had mine pretty good it doesnt take long to pick it up.
it also helps to say select 6th or a close by gear and then select reverse. as sometimes reverse was a bit tricky!
wow you guys are aggressive!!!
I've driven 2 cars in the past with dogboxes daily and it's not that bad unless you are stuck in bumber to bumber traffic.
First gear, clutch in and wait for the input shaft to slow down before you put it into gear. Upshift, just double clutch and shift into the nxt gear. Downshift will require a little bit of rev match and double clutch. If you get too much noise or pain in your left hand from the dog engagement....you are not doing it right.
YOU SHOULD ONLY CLUTCHLESS SHIFT AT HIGH SPEED.
Ah yeah double clutchin, good point. A must on down shifts. Better start practicing heal and toe driving lol.
Cheers mate, the more pointers the better
yeah i did find the dog box best at high speed :woot: and the traffic was a killer
cheers
Have you ever driven a dog box? alot of what you have written is total BS
missing a gear does not mean coming to a complete stop for starters.
Edited by URAS
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
