  • Replies 222
Posted Images
Only problem with those bastards is you need a friggin $2 coin to get them off the line.
I stand there for 20 mins with the cheque book open but the bloody things don't accept them.
yeah they are a little out of reach for a lot of people
OK, its official...
I tested a wollies trolley and a coles trolley...
I push them both down an ramp in a shoping centre...
The Wollies trolley made the bottom first so technically it won, as the Coles trolley got caught on a 5 year old and stopped... So if it were gauged via a drifting score Id pay the Coles trolley for technique as it decided to claim a 5 years old face in its basket before attempting to run him over with a blood nose... If it were an out right race well then the wollies trolley would win as it avoided said little people... :D
I say technique is what it's all about!
Sure you can get to the line first but how entertaining were you along the way?
I suppose were talking about two different sports here though. Woolies for Drag, Coles for Drift/Track, Action for Drift (Hydraulic H/brake).
Michael - That'd be great. It's good to see you admit my setup is better and you feel it necessary to assist so you might get a glimpse of the golden eagle.
hahaha....i only say its better cause your copying a superior setup already :D Well it might not be superior, but i think it is and thats all that bloudy counts....screw everyone elses opinion, fricken arseholes!
I really shouldnt have told anyone i had a dry sump setup, or let anyone see it. Im getting heaps of people asking for info and even bits and pieces now. I should start a business.
Edited by r33_racer
Come work for me doing FMIC installs and turbo timers YEAH!!!!!
I think the person ur looking for there dan is markimak >_<
P.S we all know MY setup is much better :rofl:
what are u implying shaney poo..
stuff installing turbo timers lol.. friggen electrics. :laugh:
ill even put ur engine back together and in shane as ur taking soo friggen long!
im not implying anything :rofl:
and its not the motor thats taking for ever (it could do with more work though lol) its all the other gear associated with a decent quality build, spose u wouldnt know about that though *shrugs*
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
