Hey i've searched around and found Hicas removal for GTR etc, but nothing specific to cefiro, 32 etc.
I'm in the process of removing my hicas lines, as i've had a lock bar fitted and blocked up the lines, and since then i've done a rear cradle swap also. so basically i want all the lines gone completely.
Started by removing all the plenum etc, to make life a bit easier.
1 - Start off with a pic of the hicas unit in the engine bay.
2 - Next there are 4 lines going into this one area, what is this going into? is it the steering rack (i've read that the hicas has nothing to do with the steering rack in other threads).
Can i simply undo all 4 of these and put bolts in them to block them up?
3 - This is how my hicas has been blocked off for the past 2years. I'm wanting to remove all the lines completely.
4 - Following the blocked lines up toward the engine bay, i came across this joiner/block with the lines running into it. What does this do and once again is it simply a case of removing it.
5 - Up further from this joiner/block the 2 rear lines go into this spot where the 2 lines from the hicas unit go into also (same part as pic #2). once again - simply remove and block up with bolts?
6 - Back in the engine bay i've now got the hicas unit again. the front line in this pic runs down the front of the crossmember and into the rear of the power steering pump.
7 - At the rear of the power steering pump is the hicas line. Can i remove the line, remove the pump's wheel (HOW DO I DO THIS???), and block up with a bolt?
Thanks again for your help it is EXTREMELY APPRECIATED!!!
cheers
-Matt
https://www.sau.com.au/forums/topic/170584-hicas-removal-issues/
2- Four hicas lines on the steering rack, this is simply a connection point for the hicas lines, you don't even need to plug them up, just remove the lines connected.
4 - Trace the lines from where you have blocked them right up to where they connect to the steering rack, removing any connection block things along the way
5 - Same picture as 2? Just remove those 4 lines, I don't think you can remove the block. Also, that looks freaky with the guy in the background of the photo.
6 - Should only have 2 lines left at the hicas unit now, 1 is supply from the pump (high pressure hose) and one is return to the reservoir (rubber hose with clamps). Remove the hicas unit.
You have a couple options with the hoses.
You can disassemble the P/S pump and remove the internals to the hicas side and plug the outlet, you will also need to plug the hicas return on the reservoir
Or, what I did was get a power steering cooler off an R32 and using the old hoses from my hicas removal, piped it up between the spare outlet on the pump and the spare inlet on the reservoir.
Yeah, the simplest option in regard to piping is a non hicas pump and reservoir.
But you would have to go to the effort of replacing your pump and reservoir, and buying them (money).
As simon-ae86 said, the cooler offers more reliability, plus you don't have to pull your pump apart or replace anything.
I know nothing.
Have you got the spare pump huddy????
See you Monday.
Oh and congrats on 5 yrs mate.
Edited by 32 4whore
"Charlie! We're gonna go on an adventure, Charlie!"
I was mid way through my engine conversion when I did my hicas removal. But the power steering stopped working, turns out the pump was rooted, but I thought I had stuffed up the hicas removal somehow.
Just make sure you don't run the engine without power steering fluid in the reservoir.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
