Hi guys.
Well my car has had issues as per this post.
http://www.skylinesaustralia.com/forums/in...howtopic=169954
So basically last night i put on a whole new ECU and issue was still there no change. so i guess it's not mapping or anything.
The cold start as you can see sux, and i noticed a spike on the AFM, no idea what that means.
In the Surging log, you will see that the O2 sensor drops to zero half way though the boost building ie: airflow. and then comes back, fairly apparent in the first 10 runs. I have no idea what couses this, but on another ecu it did exactly thesame.
WHat could be causing this.
Can somone with some knolage have a look for me. PLEASE.
Wogs_Log_Files.zip
  • Replies 44
Posted Images
i dont have any software to read through all those logs, but ill recommend again to try yet another AFM just to tripple check thats not the problem. any chance you can also borrow someones AAC valve as those 2 would be the first things i'd be checking (even if you've already double checked them - once more wont hurt).
Hay mate, had to different AFm on it, and i have a NEAR new ACC valve, and it's not that.
Had a different computer sotck and mapped, and same issue.
Maybe i will try a new O2 sensor and remove the cat sensor.
just some of my observations...
1. you are maxing out your AFM :woot: and by the looks of it the wiring from the AMF has a bad ground as if it is earthing out somewhere. this is possible causing your surging.
2. you are running way to much timing at full boost possibly to much between 2000 and 2600 rpm.
cheers!
HAAAY MATE your my herrooo.
Ok so how do i check the wiring, i suppose just go through the whole loome?
How did you pick up the wiring earthign issue? so i can have some idea what to look for if i fix it?
I know the AFM is maxing out, but need to put up withit, will the maxing out couse a surge?
The timming has never been an issue before this started to happen. It worked fine for 6 months, and teh ecu is read only so i can't reprogram it.
Maybe beace the SAFC II i took out -10 on the fuel map, it is puting in too much timming. Humm will need to put that back.
OK so how do i actually fix the AFM thing, apart form an Z32 airflow meter.
Any reasdon why the O2 sensor drops out like it does?
check the AFM wiring.. it could be shorting like ceffie said.. look for exposed wire or anything out of the ordinary.. if your AFM is doing anything wrong, it will throw out everything.. idle, power etc.
Ok well last night i go tin late, but i did manage to pressurise the FMIC and piping, minus the plenum, and all good, pressure at 50psi stable and holding, managed to blow up the end caps i was using though. LOL.
Put in new o2 sensor, still thesame. I have started with the wiring, but dam there is a lot of it. Hoping to do a lot more tonight with the wiring issues.
Follow the wiring diagram and go from there.
If you have any more ideas keep em comming.
Thanks guys, i know i seam a pain in the ass askling all the time, but here in tas there are no people who have a clue, yeah a mechanic will look over it, but have no idea what to look for on an imported car.
Thanks
Thanks
Sounds like you've got a leak under vacuum if the 02 sensor goes to zero before it gets to boost. Please dont tell me you've vented the rocker covers and havn't bunged the PCV vavle. Also if there is too much base timing then you can sometimes get an idle surge. remember the only proper way of checking the base timing is to do it with a nissan consult - bar none!!!!
I have Consult, and yeah the base timing is at 12 due to runing lower octane fuel.
The 02 sensors goes to zero WHILE on boost, that is the strange thing. No i acctually took the tubo outlett off and then the intake off. Then ganged one up and put a cap with a pressure line tap in the other and pressurised up to 50 psi. So it bypassed any of the PCV stuff.
I Have pulled the PCV off and checked and it was warking correctly.
The sure is not at idle, it just that it doesn't start properly, the surge is coming onto boost at low rpm but high TP.
The timing will be 12 because you have too much bypass air around the IAC, screw it in until the base timing comes back to 15 deg.
no i have set the CAS to 12 deg base idle, the car was tuned on 98 plus, and i am running premium at the moment. I have gone back to 98 plus and it made no differance after i reset the timming.
Ok i will post a new log modified to show the things i am talking about.
Ok modified surging log, about 1/3 of the way in very obvious, when viewing load RPM, AFM, O2 and TP, and have a look you will see that the air is ramping up but the 02 drops out.
surgingcold.zip
(im just using excel...i found the points, i edited post above)
after looking at that, the times it happens you either arent putting your foot all the way down, or ur TPS is very slow to react. maybe TPS needs adjusting/replacing
look at the blue line:
and notice the dutycycle drops off, ie the ecu is purposely putting less fuel in. my guess is that the drop seems consistent from switching from open loop to closed loop. TPS then only hits the full 4V after the ecu has decided to enter closed loop mode (ie cruising/14.7:1 AFR).
what happens if u run with TPS disconnected? (im not sure if thats a limp mode condition or not)
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
