pm replied
few more updates to the first post. airbox is back up for sale
std airbox $60 ono
Boot interior(minus carpet) great condition - $40
arial assembly - $50
  • Replies 43
Hey hows it going. Unfortunantly i'm in brisbane however there are several parts that i'm very interested in getting off you.
I'm after
left hand head light
steel brake pipe from master cylinder to left hand front wheel arch on non ABS r33
stock front shock
rear speaker covers
If you have these parts if you could send me an email with pictures of these and the price you want, i will get a courier to collect them.
If you have these parts and there in half decent condition i will definantly buy them off you, so don't sell em
Thanks a lot
Steve
[email protected]
hey was just wondering if they are the side mirrors are the same as the one on a r33 96 series 2 and if so how does $35 sound and with the ariel is it comlpet th ariel arm intact thanks graham
I'm after
stock front shock
rear speaker covers
Thanks a lot
Steve
[email protected]
The left hand headlight looks like it's sold atm. I'll get back to ya about the rest!
I'm looking for the factory passenger side headunit/din slot bracket, have you got this? If so how much for pickup or local postage?
Sorry but that was sold a few days ago
how much for the engine loom? if ur willing to take it off
Dont really want to separate from the engine at the monent
the actual mirrors should be the same, but the colour might be slightly off. i think theres 2 different types of silvers between S1 and 2, i'm not positive though. I'm looking for more than 35. the aerial will come complete with everything
Cheers
Edited by phatlavish
Yo enquiry bout the LH front guard - $140 ono Can you msg me and hold it for me as im gunna need it mate will confirm in 2 days via pm at this stage its a yes
Cheers Mate
Adam
Cheers Mate
Adam
Pm sent
  • 4 weeks later...
Hi Mate,
Ive replied to your PM re the tray. I'll take it :thumbsup:
Also do you have this part? It's the door connector thingy, I want drivers and passenger with all the plastic intact.
I'll probably think of more parts later when I come and pickup the tray.
:thumbsup:
ok im chasing both gear and handbrake boots long as they in good nick no rips or fraying
also need the piece in the horn button assembly that contacts the terminals for the horn or even the whole centre piece will do..
and also maybe the driver door window switch mines a bit funny but still works tho
let me know cheers
