If I get a full exhaust (3inch or greater) including turbo dumps, and install power fc, maybe 15 pounds of boost, what kind of performance should i expect? Roughly what HP would i achieve? standard turbos aren't much good for much more boost afaik, is this correct? I have a K&N airbox insert, is this sufficient?
Is there anything else I should be doing? oil air separator maybe?
The car is mostly only driven on the weekends, and will attend the odd track day.
Cheers
Simmo
Simmo, by the end of this week, i will have PFC, 1.1 bar, exhaust (on there atm), cam gears and filters and i have been told to expect 230kw @ all 4... so yeah, in excess of 400HP and mid 12's would be easy to accomplish with that power...
What? You snapped a driveshaft??? Geez what were you doin??
I've got full exhaust, filters, adj. cam gears, 13psi (0.85bar??), which produced 215 kws at the rears. With stock clutch I managed a 12.3 @ 107mph (Calder Park), so with Power FC and a bit more boost, 230 kws would be achieved very easily..... and maybe dip into an 11 sec qtr.....
Thanks guys, Prank your using standard turbos? Have you got your car back yet?
mmmm nengun has pfc's cheap atm, tempting!
Whats the best option, use a avcr or the pfc boost control kit?
thanks guys
Simmo
Originally posted by Nismodified
the limit of the stock FMIC is about 400hp @engine
which is about the limit of the injectors, clutch and such as well.
expect time to be mid to lower 12's pending on how hard you want to launch
standard cooler is good for over 500hp,im running standard and im over 300kw at the wheels.
Originally posted by PranK
ethan, Rear wheel kw? or 4 wheel? theres a big difference...
cam gears will be next.
depends whos dyno u use,ive had my car done where i get all my dynoing done in 2wd and had readings on other dynos in 4wd and basically the same.
i guess the difference is the guy who does mine basically does just gtrs and his dyno reads virtually exactly the same as the the 4wd dynos in melb.
same dyno as ethans was done,his car made 240 rwkw and i reckon would read the same on a 4wd dyno.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
