for genuine URAS bodykit for the 34 go to sleeka spares. they're the only URAS dealers from SA.
i'm getting my kit from there. you'll have to wait a long time but it's well worth it.
pics of the URAS kits are from www.uras.com.au
Sleeka Spares
11 Langford St
POORAKA 5095
-David
Edited by Advent34
Id also recommend Sleeka spares aka Fours N More Automotive.
People would think from sound of it they wouldnt provide kits etc, but as someone said theyre genuine URAS dealers. Also an awesome mechanic if anyones interested. Myself and my boyfriend get both our skylines serviced/repaired there. Awesome work.
Why not just leave the body standard.
A good ride height combined with good offset jap wheels is enough to make a 34 very nice (just my opinion).
Minus the rear spoiler maybe.
Think about the positives:
#Dont have to deal with a panel beater (even the good ones are a hastle and will need to keep the car for ages)
#"Less" cop attention
#Much cheaper
#Can spend money on other stuff
IMHO Body kits look great but why bother to try to improve the look of a car that looks good (and reasonably unique) already...
#Much cheaper
Thats what ive done :rolleyes: lowered, sweet rims and no spoiler. Defenetly turns a few heads.
  • 2 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
