hi, i recently bought an r33 with a microtech lt8 sequential fire ecu, the car also came with a duel stage boost controller, but!, it has been disabled and tells me the ecu controls boost settings.
the car also has:
550cc injectors
dump pipe into stainless 3 inch
bigger turbo
front mount intercooler
pod ect.
= 221kw at the wheels
now... i didnt get a hand controller to change the settings, so my car is set on... what previous owner called economy, pushing 7 pounds boost and fuel is managed to run at certain level ect. and cant change settings.. when i ask people about it, they tell me it wont control boost settings. I dunno, who is right???
also if i bought a hand controller. will the settings the previous owner used be loaded up from the ecu? or are the settings (maps) saved on hand controller? will this mean i might have to get my car re-tuned on dyno?
if anyone has any info (cause it has me stuffed) hehe, that would be great.
thanks
https://www.sau.com.au/forums/topic/171090-microtech-ecu-info-please/
if you dump more boost into it, then the tune is not correct for the amount of boost you raise it to, if you want more power raise the boost and get a retune done on the ecu.. the handcontroller is only usefull to a user if you want a read of digitaly, for a tuner it can be used also to tune the car, so be carefull not to hit the *mode* button when you get one as this will set the computer into tune mode, and you will alter any settings... not advised unless you know what your doing.
so im stuck on 7 pounds of boost, unless i get it dyno tuned?
Economy and microtech should never be used/talked about in the same sentence, they don't belong together :thumbsup:
I'm sure you can tune the microtech for "economy", but yea, it's pretty p*ss poor in that department.
I probably got a MAX of 300-350km/tank(60L tank) with the RB20-DETT, and i generally drive pretty old lady style.
And no microtech can't control boost.
Edited by Jago
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
