  • Replies 67
my rock hard tyres would be perfect for sideways.... heh.
theres a bit of time to get ready now so DOO IT!
Chris:
r u serious.
i was having kittens running arround looking for tyres and getting the car ready this arvo.cause it was the only day i could get it ready this week.:action-smiley-069:
im glad i diddnt rip the front bar off.i was going to leave that till after work.
Guys,
Its this coming friday :thumbsup:
However....I may be out :(
having steering dramas so Im hoping my car can get booked in early this week.
I *should* be right
fair suk.hope you can make it still chris.
my drain plug is stuck in the box and i am pissed off.last time i put the plug back in i got a bit happy with the loctite and tightening.now i have to wait untill tomorrow to take the car down to a gearbox place.this weekend i was supposed to have it all out and ready to pick up the clutch for install by tomorrow.tho this has stuffed me right up now.i want the plug at least loosened so i can get the blasted thing out.a mechanic has allreeady tried and he said the only other option is to drill or weld a shaft and remove.if i drill then it will prolly mean the box might to come apart because of metal shavings :?
i will still come out to drift the car even if the clutch is slipping a bit.ill get the most out of the clutch ftd :(.then after i will look at getting the clutch in and out.the only thing that will stuff me is clutch kick entry i will have to unsettle the car to initiate drift....eeek..:P.good times.
clutch kick ftw :P
haha
yeah Craig, Im hoping I can get it done before friday
I'll make a few calls tomorrow - and at the same time hopefully someone who does the job, can fit my remaining suspension parts!
go for gold son.haha at your interpretation.
i have been sick the past 2 days so i havnt had any time to get the car looked at.not to fret,like i said i will still come out there to give it a go..but i will have to feel better though.
i hear rain untill fri.show n shine cutting it close again.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
