  • Replies 67
hahaha f**k you crack me up Brendan!! :)
Burnsie - where the f**k were you tonight????
Craig and I had plenty of fun, representing SAU NSW!
My car, Idunno, Craig and I think I need a better diff :(
and I was understeering alot more than our SAU dorri day
My highlight.....following Chris Easton around the track, that car is an ANIMAL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
wooo.... nice work chubbs and craig.... i was looking at the IDA calender and seeing when the next oranpark north day is and it wont be till december (dmn it too long) mite have to suck it up and give south a try even though it looks alot harder.
oh man.. wish i could have come watch... was all clear until last nite wen work needed me tonite... oh wells..... any pics?
sounds like ur diffs starting to loosen
nah no photos, too dark out there also!
Just keep an eye on the driftland website - normaly theyhave these nights once a month
I'll be going to the next one!
only 75 bucks!
yep - *searches for new diff*
hope you guys had a good night...
the drift king couldnt make it last night, car not 100% and no tyres to kill... been working my ass off so havent had time to prep the car or service it and stuff
but woulda looked sick on sunday with some burnt rubber on the back guards :)
OMG rofl...mikey what happened...;) you missed out on a good night..met brendan aka "nismo god" last nite ;)
boys youve got to make it to the next night out.
i diddnt even get through one set of tyres.and they were arround half tread to begin with.but i diddnt rreally sit there and fry them having said that.
chris.i went and got my old rubber put onto the front tyres.you know,after it deflated.and when i got home i realisd that it had a slow leak arround the bead.it could be that the tyre bead just wasnt seated properly on the rim or it also could be that the rim itself is buckled.but i never had the time to take it back down the road this afternoon so now for show and shine i have got my 255's up front and the stockers on the rear.go the drift look FTW!!
SAU drift on the rise from the youngling drifters :P lol!!
yeah chris.if you want one weekend we can get at your diff and get it locking like the locked bitch that you want it to be.+ a few bot's of the stags finest of course ;) hey.and next time have the car packed ready to leave the day before.hornsby traffic ftL in peak hour is just tehsuxzez
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
