This has been sitting in my garage for the last 5 months, it was in red when I bought it and was thinking of painting it silver. Got half way and I had to deal with various other crap in life, so it's currently in gray primer.
There is a crack on the lower side which I've fastened it together with a couple of cable ties and you wouldn't even be able to tell looking from front. There's also a chip on one sside whcih I didn't really know how to fix so I left it as it is. Otherwise it's in pretty good condition.
I've changed my mind lately and have decided to go full GTR front bar instead.
Looking for $100
Located in Sydney
https://www.sau.com.au/forums/topic/171219-r33-series-2-lower-lip/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
