Hey guys,
ALREADY SEARCHED FOR MY ANSWER ON HERE AND ALSO NS.
I've heard a romour that running my GTS4 in RWD mode (removing the fuse) for drift, Does not run the same as a GTSt and has bad balance??
It's been a dream of mine since i was 14 to learn drift and get to the track. My engine is currently shagged atm, so this may be an opportunity for me to switch to a GTSt drive train while the engine is out....
Anyone have any experienced opinions or guidance they wanna share??? :P
cheers!
https://www.sau.com.au/forums/topic/171278-gts4-and-gtst-rwd/
Honestly you really didn't search.. did you. There's heaps of info on here.
The short and curlies of it is, when you lock a gtr/gts4 in rear wheel drive, you are still carrying all the weight in the front end of your car.. theoretically upsetting the balance of the vehicle compared to a designed for rear drive vehicle. As well as the vehicle being proportionally heavier.
So.. you can do it, but why not get rid of your car, cos you obviously just want something to thrash, and get a bunky gtst, slap a 25 into it, and go nuts.
james.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
