yep, answering to your reply. To be honest, apart from remembering the hood pins which keeps the hoods in position either on the top side or bottom side, I cant really remember any particular hinges.
The ones that came thru me had reinforced hinges with a couple more layers of CF and also all round sides the edges.
  • Replies 56
For some good stuff look at www.customcarbon.com.au .. They do full Carbon Fibre bonnets and other stuff and they are actually pretty cheap. The stuff looks scary though.. thin as.. but strong I guess.
Tell Jason you heard about them through Rick form Yeppoon and I'm sure he'll give you the best price possible.
Is there a point in putting carbon fibre bonnets on gt-r's?. the stock bonets are already very light. I would understand putting a c/f bonnet on a gts-t cuz the bonnets weigh a shitload. just a thought.
cops - Dont think they give a shit about what you will explain. The moment they set their eyes on your car and stop you, they will try every single dumbest reason to defect you.
The whole rationale is, they are cops!!!
hahahaaa
You seem like a really smart guy. Please dazzle us all with some more of your wisdom...
Do I need to be a smarty farty ass to make such comments? I hope not though. Some officers are nice, well in reality, down in Perth, some are not!
If ya one, good for you then, but I think I do reserve the rights to make comments of my personal views. Especially when 1 of my mates got booked just because his elbow is slightly out of the door window when he's driving or another one being booked for the dumbest reason I could ever think of ... having her school parking decal not under the same side of her rego but on the driver's side! Tried explaining, the more they try to haul you in for the slightest defect such as tire thread limits and faulty third brake lights when the other two main brake lights are still working good!
Instead of catching people doing burnouts in the middle of the nights or going after drunken stupor group of youths trying to pick up fights after getting wasted in clubs, nope, they just wanna spend their time going after a girl driving a small little Starlet!?!??
Funny logic how the good "system" is flourishing ... ...
On the Evo I once considered a CF bonnet, only to find it was less than 3kg lighter compared to my already factory delivered aluminium bonnet. Like the GT-R I wouldn't bother.
If I take out my carpets or jack...whatever, I would save more than 3kg, so there isn't much point. Plus the money you spend on these bonnets, would be much better used towards performance mods which would negate 3kg anyway.
IMO CF and wet CF over fibre glass bonnets are ghey on a street car...unless your a really hardcore circuit/drag racer. It's not going to make much of a difference in performance other then impress your mates. Also if you have ever seen it, fibre glass bonnets will flex anywhere from 0.5-1+ inches at high speeds. Thus why bonnet pins are used to help provide additional fixing points to prevent the bonnet from balooning and also secure the bonnet from suddenly opening up on you when your doing a 1/4mile...the factory bonnet lock is going to do jack with winds picking up the edges. So you install bonnet pins, but hang on bonnet pins are illegal!
Stick with your factory bonnet, paint it black if you wish or an aluminium bonnet...at least it crumples properly in an accident.
don't eat junk food for 3 weeks, lose 3kg.. simple really. Its not worth bothering about from a weight perspective at all like EVO is saying.
My toolbox weighs 12kg for a start.. spare about 12kg.. etc..
but still.. I need a new bonnet.. buying a genuine one or finding one from a wreckers maybe $300.. painting maybe another $300.. total cost: $600.. carbon fibre / fibreglass one $900 or so.. may as well spend the extra for the wank factor.. they do look cool with the vents..
honestly, the cf/fg ones are really not worth that much money.
$900?? i'm not sure about it. Maybe ya better off browsing around to see if there's any better deal elsewhere ... Cause for $900, you can get a Honda OEM bonnet which is wet type full 3k cf with frp frame ... maybe those overseas retailers are worth a look ...
Abit of side track, there's even those with transparent type ones called ABS Transparent. For those car shows though ...
just my .5cts worth.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
