Hi guys, the next track day is coming up in 3 weeks. The format is as follows:
MORNING SESSION - Clubman / National
7:00am Arrive and get checked in.
7:45am Morning Driver Briefing
8:00am Clubman Circuit
10:10am Passenger Rides
11:30am National Circuit
12:30pm MORNING SESSION END
AFTERNOON SESSION - Sprint / Sportsman
12:00pm Afternoon drivers arrive and get checked in.
12:45pm Afternoon Driver Briefing
1:00pm Sprint Circuit
3:10pm Passenger Rides
4:00pm Sportsman Circuit
5:00pm AFTERNOON SESSION END
If you are keen get booked in, if you have not joined the track day group yet fill out the form at:
http://www.timeattack.com.au/mailing.php
See you there
Paul
https://www.sau.com.au/forums/topic/171409-track-day-june-26/
  • 3 weeks later...
Can anyone lend me a whipper snipper to clean out my wheels :(
Some how I managed to get a grass fire in my passenger side front wheel. First time I have seen smoke coming from the wheel and thought "hang on, that smells like wood".
I have put the best lap times up at:
http://www.timeattack.com.au/forum/viewtopic.php?p=258#258
Check out the result of the last session, the top 5 cars were R32 GTR's !!!!!!
I will have pictures up soon as well.
Thanks everyone who came out and made the most of a wet day, we did end up having a lot of fun and learned heaps on the wet road.
Paul
Another well organised day, and a fun one at that! Paul's 4wd controller certainly made a huge difference to getting the power down. Plant the accelerator and hang on as you do massive awd power slides :P. Started off with it set to just a bit above factory torque and found it was still very tail happy, so upped it a fair way and the difference was awesome!
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
