I have been using Ferodo TS2000s (aka Formula), they lasted me 9000kms of street only use.
On the weekend the last bits of one of the pads came apart and for a short period on one side i was braking with metal on metal. The backing plate ate into my new disk.. it should machine out but has taken some life out of the disk.
In terms of performance the Ferodos were great, quiet when cold, noisy but very effective when hot with great modulation and pedal feel. You would have to push very hard to experience any fade on the street with these pads and new fluid.
I got approx 17000kms out of my last pads which were Bendix Ultimates.
Taking into account street/track, car, model of pad....how many km does everyone get out of their pads?
https://www.sau.com.au/forums/topic/171414-brake-pad-life/
i change my pads when they have about 2 or 3mm of friction material left. after that they loose their effectiveness.
as for kms, I don't know, I've never worn a set out. I always change them. but I'd say probably much, much less that 5000kms.
https://www.sau.com.au/forums/topic/171414-brake-pad-life/#findComment-3163342
i change my pads when they have about 2 or 3mm of friction material left. after that they loose their effectivness
Beer Baron......very sensible
salad We should start a brake pad Hall of Fame :)
mick51 was driving, first sign of a problem was when pedal went to the floor at just over 200kph
new pads approx 280klms on them
https://www.sau.com.au/forums/topic/171414-brake-pad-life/#findComment-3163366
The pads i posted were never used on the track..
Apart from that one side, the other pads had about 2-2.5mm left, ready to be changed. I guess i shouldnt have tried my luck... i got them pretty damn hot and i figure the remainder of the destroyed one overheated and tore off the backing plate :)
51jay mate, you did a good job on those ones pictured, very impressed!
https://www.sau.com.au/forums/topic/171414-brake-pad-life/#findComment-3163475
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
