Please only enquire if you are serious;
For sale: Kayzer 18in alloys. Fronts are 18x10J, rear 18x11.5J with offsets of +2 and -17 respectively. In true Jap form they have stretched 235 and 265 boots with enough tread to get around on for a little while...
Item Condition: Awesome condition - I just had all the minor marks all polished out and cleaned up, almost like new
Price and price conditions: $1950 FIRM
Extra Info: As above, they've just been polished and restored - all centre caps are there, very tough looking wheel and hard to get in these sizes. They look heavy but are surprisingly lightweight - only 1-2kg heavier than factory R32 GTR rims
Pictures: Below
Contact Details: PM
Delivery & Conditions of Delivery: Pick up or we can sort it out
As mentioned in my other thread, here are some measurements to help see if they fit on your car;
145mm front
185mm rear
Those measurements are from the back of the centre of the wheel, where the bolt holes are (the part that sits flush with your hubs) to the outer edge of the wheel. So to see if they stick out you'll have to take a wheel off, measure either of the above distances from your hub to the outer and run a string line...that'll give you an indication of where they'd sit.
Also needless to say, they're 5x114.3 stud pattern.
Cheers,
Chris
Edited by YSR020
ey chris ill come over on the we and well try and fit them to my car, then well do a straight swap for my rims
kthxbai
Yeah Nick - no sweat...15 minutes with the hammer & dolly and they'll fit no worries... :)
very keen please post up some better pics
Hey Trent - here are some fresh pics I took about 10 minutes ago.
btw, I am in need of a (not URAS) full kit from Japan for my JZX90...if you can bring one in perhaps we can sort something out with the wheels if you like 'em... :)
Edited by YSR020
Damn it.. If I had the cash spare I would've bought these straight away (providing you were willing to post interstate).. would suit my widebody perfectly :)
damn thats a hot car!!!!
But i see how they fit lol shame they wont squeeze uder a r33 standered but rolled gaurds or id take them right now!
...bare in mind R32 sedan has the smallest guards of all Skylines, and R33 coupe has the largest guards of all Skylines... :)
they look real hot i can tell it would be a pain to get them to fit on a r34gtt sedan....even most skylines haha good luck with sale!
Yeah a 4 door makes it a little harder...that said if I don't sell them for this price I'll fit them to my JZX90 MarkII
lol tempting!!! haha if i was in melb id come around and try them on for sure, but im in adel and would die if i bought them got them posted out and they wouldnt fit! lol
Haha! That's cool mate...only stirring...but if I had to fit them to any car I reckon 33 coupe would be the most painless of all.
Cheers,
Chris
Cheers,
Chris
Which is why i am sussing out my panel beater rite now to see how much he can blast my guards out, since the car is getting painted anyway
Good man - I like the way you think! :thumbsup:
Also, I may swap for a pair of front BRIDE or Recaro seats plus cash my way...
PM replied to - NO low ball offers. They're cheap enough as they are.
If they're still available in a couple of weeks, and you're willing to post to Brisbane.. I am 90% certain I will buy them off you :rofl:
Unless something drastic happens and I will have to put the funds towards something else..
No worries man, I'm only a PM away! :laugh:
Also I'm happy to hold the wheels for anyone, if a deposit is given, am in no rush to sell. Price is fixed and will send anywhere at buyers expense.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
