Hey There
Recently got the rest of my bodykit which is Bn side skirts and Bn rear bar. A while back i got a Trust Front bar which we already fitted up but has not yet been painted. I thought id show the progres along the way with some before, during and after shots. Ill update as more of the work is finished.
Before Shots
M-spec kit removed
post-26024-1181126550_thumb.jpg post-26024-1181126638_thumb.jpg post-26024-1181126808_thumb.jpg
Thats it for now :D
Edited by iLEC
https://www.sau.com.au/forums/topic/171716-bodykit-install/
Cheers Nismo Racer their Starcorp inpuls you prolly already knew there pretty common on the skylines lol
and mid life crisis you could have washed my car before i parked on your lawn haha
:D
Edited by iLEC
https://www.sau.com.au/forums/topic/171716-bodykit-install/#findComment-3164658
hi jake im ilecs dad
we had to remove a small amount of the rio bar for the cooler .but then had to remove some more to fit the front bar. there is a fair bit of it left tho. we did not remove completly like some people do we wanted to retain as much as possiable
cheers
we took very little away from the front bumper itself wasent any need too
Edited by mid life crisis
https://www.sau.com.au/forums/topic/171716-bodykit-install/#findComment-3165386
yeah its a mixture of a veilside rear with skirts and wing with a trail front bar. The skirts on mine were hard might have been a tad small so it hugs the car but srcrew it on as well.
I'll post some pics tomorrow as well
Edited by BreathLess
https://www.sau.com.au/forums/topic/171716-bodykit-install/#findComment-3168985
  • 1 month later...
Is there any problems getting the front bar off? My new M Sport front bar is getting painted today and was going to put it on myself...
Cheers
https://www.sau.com.au/forums/topic/171716-bodykit-install/#findComment-3257566
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
