Heathcote 1/6/2003 :P
Guest RedLineGTR
We'll hope everyone got home in one piece and all, hopefully no cops bothered anyone. Would of been a good day if it didn¡¦t rain, we got there too early since the track was wet and racing started at about 12 after everyone who wanted to was asked to go on the track to get all of the dam water off...most people overdid it eg. The white WRX nearly hit the dam main event organizer..abit to much sideways.
Good turn-up of people the times for waiting for runs wasn¡¦t to bad compared to some other drag strips in Vic. Good support from Skylines (Victoria) Australia with a think about a total of 11 cars coming up in the morning in one group and bout 3 rocking up later.
It was a good day, caught up with a couple of people and met more people on the forum. Hopefully next time, if there is a next time I will have my car ready.
Good show up of different cars...Skylines, rx7, wrxs, fords, commardores, rx3, 200sx & some other classics. The Rh9 r34 gtr was there ran 12.5 or something like that close to 9 ƒº. GTR700 was there ripped 9.15 something close or lower than that, we were hoping for high 8¡¦s but it started to rain before they would have another run. Which cut the day short to about 3pm or so.
Got about 64pics on the digital camera will upload them soon when I get a sec & also we got some video footage about and hour so that will be getting edited soon and hopefully we can make something of it. Post ya times if you want.
https://www.sau.com.au/forums/topic/17234-heathcote-162003-p/
  • Replies 162
My best time was 15.18 which for a first timer to the drags wasn't too bad (I guess??) though I was hoping to go under 15secs........
Today being my first time running a car at a drag meet I must say that it was a blast and I can't wait for our next outing to the drags.
Rowan
my best was 14.4 i believe - didn't get the timeslip tho as that was just b4 it started pissing down... Guess it was better than the other GTS-T's ;) so can't complain too much.
Those 225/50R16's didn't help much - next time i think i'll just use my regular street 17"s
Guest RedLineGTR
Originally posted by predator666
its definitely good fun yes.. i wish u could just do away with the helmet to actually hear what the car is doing :-| i guess that is part of the challenge!
Those helmets were annoying from what people have said...thoe you cant hear your car because of it, it dosent help when you have some old ford with no exhuast reving the fark out of their car near you.
haha....yeah those darn helmets..now i know why people use shift lights.;) my best time was 15.28....also not bad for a newbie with only an exhaust mod. R31Heaven ur not the only one to stick it into 5th instead of 3rd....haha.i couldnt stop laughing at myself ... though i did pull a 16.12 out of it...haha. had an awsome time...and the drive back was fun too. the gtr vs sti was a good match, both managing to get identical times of 13.08 or was it 12.08, cant remember.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
