check out my user gallery, I got one made by CustomCarbon in QLD. It's damn light an awesome quality!! (think its customcarbon.com.au?)
theres heads of the Jap type ones out there with the fibreglass underside, checkout nismo.com.au carmate.com.au justjap.com.au
Yup, there's a number of threads on CF bonnets, but no matter how many there are there's never any info on where to get a Z-tune styled one :kiss:
carmate does the z tune style in both fibre glass and carbon fibre
looks nice, im lookin at gettin one soon. how much did the sting you for that?
friends old 33, with one from justjap..
Cheap copies dont line up properly..
Theres always a little gap.. as you can see
looks awesome none the less..
Buy eastbear stuff!! $$$ but worth it..
Edited by siddr20
cost me $2000. its only 2 layers of carbon an weighed between 6-7kg.
Stock bonnet = 25kg approx
fibreglass bonnet = 18kg approx
Jap made carbon bonnet = 15kg approx (there fibreglass bonnets with 1 layer of carbon put on the top side)
GTR alloy bonnets are close in weight to the Jap carbon ones, but....dont fit gts-t's (well the 33 ones dont anyway)
um cost him 1k max from just jap..
Not to sure if they make them for series 2 tho..
This was series 1.5 i believe.. Series 2 are a little different.
Best carbon bonnet i have seen is either east bear stuff..
I remember yonks ago, there was a guy from interstate that made it himself for this 33 gtr.. Maybe search for that thread!!
Heres a few pics of carbon bonnets: Not exactly sure if they are real or just fibreglass.. But just some pics for you!!
and i got lots more.. but cbf lol..
Check out topstage.. he sells nice bonnets!!
But i wouldnt bother with one to be honest, unless its a plan design, without the huge whole in the middle.
Water and other crap will get on top of your engine!!! not good !!
hahahah after talking to ya, i knew it was yours!!
Seems like you changed your rear bar since then?
drew2-- i got plenty more pics!!
n btw customcarbon doesnt exist anymore??
or they changed there website??
Edited by siddr20
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
