Hi
Can you please find numbers for all breather hoses on/around rocker covers RB20det HCR32.
Cheers
not sure if these are the only ones you need but.
11826-04U10
11826-72L10
11826-73L10
they are onto LH rocker cover, then to from LH to RH rocker cover, then RH rocker cover to inlet plenum
Hey there guys im just chasing order numbers or part codes for:
1995 series 1.5 R33 2 door coupe - Drivers side window surround.
1994 series 1 R33 4 door - Lower sealt belt pillar cover.
  • 4 weeks later...
Hi, just wondering if you know the part numbers for a front bumper support for my 2000 4 door GTT , i think its a series II
im after the middle and 2 side supports , they sit right behind the front bumper
and also if you can tell me how i might get my hands on some ....
i rang nissan ...was no good
thanks
Hi,
Im trying to find the part numbers for the R32 GTR bonnet lip, and N1 vents for the front bar (right and left) in gun metal grey. I appreciate that this info is in this thread somewhere but the search function is non functional at the moment and Ive looked through the thread manully with no sucsess. Any assistance is much appreciated.
Cheers, Sandy.
hey got a R32 Gts-t coupe is there a gasket 4 the fuel pump and if there is i'd like to know the part number please also the number for a rear diff pinion seal?
is there numbers for tie rod ends? R/H/F if that makes any difference?
yeah nice thread keep up the good work Thanks
Hi,
Cheers, Sandy.
N1 bonnet moulding part No. 65820-06U25/ f5820-05U00
may have been replace by latter No.
Rh bar vent 62256-05U08
LH bar vent 62257-05U08
Fuel tank sender unit/pump seal 17342-01A00
pinion seal working on r32 08/91-02/93 with hicas, RB20det. part No. 38189-N3111 (there are also 3 other option so need more info)
RHF tie rod end part No. 48520-71L25. for 2wd
in ending more info is needed for correct info
Edited by neofenrir34
Does anyone have the Part Numbers for the following:
R34 GTR with brushed silver dash -
* Ashtray
* Stereo Fascia surround
These numbers suit 08/00 onwards (get local nissan dealer to send a parts query to find out if they are silver)
Stereo surround 68260-AB100
Ashtray 68800-AB100
* Ashtray
Ashtray 68800-AB100
thanks
not sure if these are wat u are trying to explain but
62216-AA010
62217-AA010
ref picture.
try your local dealer again they where most likely to lazy to look the part up
1993 R32 GTs-T RB20DET with hicas (diff is a LSD)
model number: HCR32-290387
but thanks man :P
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
