  • 3 weeks later...
Can i please get the part number for a 1991 r32 gtr clutch pivot ball as nissan sent me the wrong one. Its from a push type clutch. And how many different types there are. i really need to know. Thanks much appreciated.
Part No. 30537-40P00. Only seem to be one option for a RB26 engine in a R32
Someone Iv been looking for :rant:
Have you got the part number for rb20det, 1993, r32 skyline. Iv been tryying to find pressure plate bolts but cant seem to get them off Nissan because my car is auto and doesnt have these bolts so they cant find them :D Doing a manual conversion.
but i need:
Pressure Plate Bolts
Airflow meter plug (if there is one?)
Thanks
  • 4 weeks later...
Looking for a few part number for my 93 r33 GTS25t !
- Set of 86mm piston rings
- L and R rocker cover gaskets
- L and R rocker cover half-moons
Thanks in advance for your help
  • 3 weeks later...
Hi my name is Brig I have a project car i need a ton of stuff. hoping you could help with part numbers list. If possible i would like a complete list my email is [email protected]
1991 nissan skyline GTR
color- gray
model-KBNR32RXFSLMZG
Chassis-BNR32014830
Edited by Brigironx
  • 5 weeks later...
Well it's a horrible diagram with horrible descriptions... but it looks like they probably ordered you a 24079-05U00.
That leaves you with a 24077-05U20 Harness Assy-Engine or a 24079-05U01 Harness Assy-EGI Sub.
thanks simon
we'll see what they have to say - the 24079 is what they ordered me originally which turned out to be the coilpack loom
-D
Yeah it's pretty obvious that 24079 is a coil pack loom... but it's a bit trickier to tell the other two apart.
it looks like the injector loom is part of the main loom that comes from the ecu ;\
-D
does anyone have part number for genuine rear vision mirror inside the car (r33 1994 s1) ??
cheers
comes as complete assembly.
96321-70T01
go to a wrecker, this will cost a fortune from nissan.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
