- heater box for r32 x 1 - -$30 each
- powersteering resivoirs x 2 - $20 each
- hicas pump and lines - $30
- white pearl 32 sedan boot (no damage, but no wing) - $40
- white 32 sedan boot tiny dint at back with type m spoiler - $80
- 32 sedan headlining (non sunroof - will not fit a coupe) - $30
- front cloth seats from a r32 - $80 both
- front passenger seat velour r32 - $50 ono
- r32 dash in ok condition 1 circle mark, not lifting - $50
- white pearl r32 bonnet tiny dint at front just above where the headlight is - $80
- Maroon LHS r32 guard few dints (from half cut) $30
- White pearl and white front RHS guard both have damage $30 both
- Maroon r32 halfcut stripped good for a crashed car to repair
Will also sell all front panels above for $450 ono
- 2) r32 rb20 turbos, i would say both nee a rebuild $50 each
- 2) r32 wastegate acuators - $40 each
- 6 rb20 injectors $50
- r32 automatic transmission, was shifting fine when took out to convert to manual - $50
transmission also come with flywheel and stall convertor
- rear k frame from r32, no diff - $80 ono
- r32 veilside coupe rear bar - brand new never fitted - $200
- r32 gtst m-sport 20mm wide guards (brother bought this for his GTR and they are for a GTST) - $150
Also have many interior bits and other parts from a 32 sedan.
Plus many engine parts as well
Prices are negotiable and i need to get rid of this stuff
Pics will be up soon for a few items, anything else pm for pics ill post
Also i do not have dash vents
https://www.sau.com.au/forums/topic/173091-parts-clearance/
  • Replies 49
Hi mate,
- what condition?
- $150 for both?
- location? if u not in Syd, are u willing to post?
- some pics would be good
Cheers
Edited by subie
https://www.sau.com.au/forums/topic/173091-parts-clearance/#findComment-3183471
hitoriko PM sent
subie - yes its $150 for both and are in brand new condition...never fitted.
I might post ill have to get a quote and make sure i can pack them properly so they dont break
Ill get pics for you 2moro
Cheers
https://www.sau.com.au/forums/topic/173091-parts-clearance/#findComment-3183834
Pics
Also have 32 coupe lights (both have broken outsides can be fixed) - $50 both ono
32 fuel tank $40
front cross member, hubs and some suspension parts (one stud is bent) - $150
32 4 door mud flaps (2 sets) $20 each set
https://www.sau.com.au/forums/topic/173091-parts-clearance/#findComment-3185953
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
