  • 3 years later...
Hey everyone, didnt wanna start a new thread
Where do I buy federal 595's from?
I live in perth, so locally would be nice, but if it was a fair bit cheaper online that would be okay too ...
Putting them on ROTA G - Force + 35 offset in gunmetal grey :blink:
looking at 245/40 for the tyres, all 4, would rather be able to rotate tyres etc
cheers everyone
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5574842
Highly recommend the 595's!
I got them about a month ago and they are an awesome street tyre.
Go with option1, even with postage you wont find cheaper, and extremely good service to boot!
What width are your rims?
I'm running 18x9 +35's and went with 255/35's. They are the perfect width for 9 inch rims and look sweet!
You'll find 245/40's have a much larger diameter than stock (595's however don't come in 245/35's) where as 255/35's are as near as dammit exact.
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5575098
thanks for the replies everyone :blink:
the wheels will be 18 x 9, 5x114.3 +35 so basically the same as yours Bomba :P
our rims also look kind of similar hahaha
ill make sure to check out the 255/35, i didnt really want anything too thin though, 255 isnt too wide? i was recommended 245/40s by the guys at tyrepower etc to be a somewhat practical size
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5575134
You'll find 255/35's aren't too "thin", as far as ride harshness I can hardly notice the difference between them and the stocko's. If you look at the comparison pic the side wall is still quite tall.
As for option1 not having them, they don't show all the sizes on the site. If you email option1 during business hours (or contact them through their thread on here) you'll find they'll either have them or will be getting them in shortly. They order frequently and if they are out it wont be long until they have some again.
Again I highly recommend the 595's in 255/35's, they fit spot on.
FYI tyres fit differently depending on brand, for example Kumho KU31's in 255's look the same as 595's in 265's (too baggy for 9inches).
Have you considered the Kumho's??? I was going to get them in 245/35's until I saw the 595 255's on my rims, mmmmmm sexy!
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5575224
yeahh i was looking at the KU31's, they were what was gonna be supplied with the rims im ordering, but heard sooo many good things about the 595's .. and well .. the tread pattern is awesome LOL
cheers bomba, ill give them a call/email tomoro during business hours :)
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5575282
hey does anybody know where to get tyres fitted/balanced in perth?
a guy at maximum motorsport said that it'd cost 10-15 bucks (not too sure if he meant per tyre though ..)
and tyrepower up in osb park quoted me 160
whats the usual prices paid to get the rims fitted with tyres and balanced etc?
so far for a set of 595s locally itll cost me 235 per tyre .. 940 total cost fitted/balanced
but if i order from option 1 its 160 per tyre, and 115 bucks delivery, so a total cost of 755 for the tyres ...
if its gonna cost more than 100 bucks to fit and balance i really might as well just get em locally?
Thanks everyone :)
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5578494
joey you just saved me alot of money :)
because of your link i checked out the 235/40 locally in perth, veeery much cheaper
175 per tyre vs 235 per tyre
definitely gonna go for those :) works out 15 bucks more expensive than if i got em off ebay/got em fitted and balanced
thanks for all the help mate :)
https://www.sau.com.au/forums/topic/173504-tyres/#findComment-5580562
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
