Hi guys
i get this wierd noice from the front. the noice seems to start when im traveeling from 60 onwards and is at its loudest at 100.
When i first heard the noice it thought it might have been the diff so i changed the diff oil i put penrite diff oil and also some nulon gear treatment. the noice was still there. i got a wheel alignment and rotated the tyres the noice went away for a while but it came back. I had Hankook Ventus tyres and was told they are the reason im getting the noice and they are crap.
i now have a second hand pair of dunlop sports 255/55/R16 on it was ok for a few days but the noice is back again and it is just as loud. it is really annoying. It hard to explain the noice sound like but it getts so annoying i have to turn the radio up. to block the sound out.
oh and another thing is when you open the window you cant hear it either
any help would be good.
https://www.sau.com.au/forums/topic/173645-front-end-noice/
Your going to have to describe the noise a bit better.
There are some basic diagnostic things you can do.
Does the noise increase with speed or with revs?
If its revs it might be engine or possibly gearbox.
If its speed it could be tyres, wheel bearings, diff, etc.
Take it to your mechanic and take him for a drive, see if he can diagnose it.
...and by the way its "noiSe" not "noiCe".
Good luck fixing it.
https://www.sau.com.au/forums/topic/173645-front-end-noice/#findComment-3191192
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
