Just a few hours ago I found my garage door open and both my R33 GTR and R33 GTST broken into....
My GTR had its window bent back and a pioneer deck stolen. Dash is all smashed up in the process... Also had the word "DONT" scratched into the bonnet... left side mirror broken... climate control and center gauges ripped out...
My GTST had the driver side window smashed with a brick, my pioneer tv/dvd stolen as well as my blitz turbo timer and dash smashed up in the process... also my leather interior has been poked with a screw driver...
Feeling so down right now....
Have reported to the police not that they can do much...
I believe the get away car may have been a taxi as I saw a taxi screech off at about 2.30am...
The taxi also hit a car parked on the street...
Didnt think anything of it at the time.
https://www.sau.com.au/forums/topic/173722-both-my-r33-skylines-broken-into/
  • Replies 104
oh man that sucks
you havent
-rooted any ones misses
- chopped any bogans in commodores/falcons
- yelled at shickcarnts out the window
- stolen money from ya mum
sooo bad man, atleast they are still both there!!!!!!!!
oh man that sucks
you havent
none of the above man...
Im just shattered.............
mate sounds like someone really hated ur car aye, cos they wouldnt do anything else other than get wat they want & go but instead had time to write 'DONT' on the bonnet & cmon...poke screw driver on a leather seat....kinda personal issue dont u reckon?
but damn hope those low life scum get caught.. karma will get them one day.
Edited by gwaping2k
man thing is I have no issues with anyone... :O
Im at guildford.
damn dan... feel for you. esp with the wedding coming up et al. The f**kers who did this will have pandas for kids ( no offence to PETA members here)
yeah its bit of a backward step...
Will have to sell both cars now... :O
$17000 for the GTR as is.
$16000 for the GTST fixed.
You don't have to have issue's with them, alot of it is there just jealous of what you have worked for and they know its something they'll never have ,there infearoity complex and they'd be right they are infearidots best of luck with repairs
thanks man
Yeah that's true. It pisses me off even more when these pricks don't just steal things, no, they feel the need to trash everything else as well.
thats the thing the damage they have caused trying to get to the head units is the worst and most costly thing...
Sorry to hear Dan... Hope all gets sorted ASAP...
Hope the jerks that did it get caught and are dealt with the way that they should be...
This kind of act really $hits me to tears!
There are so many inconsiderate people in this world! If you have a problem with someone, you take it up with them in person! One thing you don't do, is deface their personal property!
I've had my car keyed a few times by my next door neighbour, i know its him, and he knows that i know that its him!
But still, the dickheads still do it!!
Again, sorry to hear dude... Good luck
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
