Both my skylines were broken into yesterday and had both head units stolen and the interiors trashed in the process...
R33 GTR need:
passanger side window.
seal that sits on the door to hold the window in.
Glove box.
gear surround and dash thing that has the air vents, clock, etc in it.
R33 GTST need;
Ignition barrel and key.
Door locks too.
(the bastards stole my spare key which I foolishly left in the centre console....
need these parts ASAP and hopefully at cheap prices... ;)
https://www.sau.com.au/forums/topic/173766-both-my-r33-skylines-broken-into/
shit man... that sucks...
can you take pics of the parts that need replacing...
if a wrecker doesn't have the window seal, I might be able to source one for you.
just not 100% sure which seal you mean though
Cheers,
Beau
I got a dash surround for the 33 Gtst - your welcome to have it for free! All vents, clocks etc in place...
good to see someone trying to help another guy out for nothing... well done mate
:cheers: I figure what goes around comes around. If I was in that situation I would hope that people would be willing to help me out as well....
btw Dan, PM sent
btw Dan, PM sent
anna thank you so much!
Its such a big help as I am so strapped for cash... :D
  • 4 weeks later...
hey bud
if the Glove box is the same as the gtst i got it
dash thing that has the air vents, clock, etc in it. which i got
i got complete r33 lock pack with key, immobilizer,ignition barrel,locks.
check link below
http://www.skylinesaustralia.com/forums/in...p;#entry3235168
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
