anyone interested ok guys 28th july it is, darrin will source the spot with address and directions, i cant make it till around 2.30 so hopefully after 12 suits all, we'll have a bbq so bring tucker and we want a bit more interest so hopefully we might pick up a few more stags before 28th,
cheers,leigh
Edited by leetom
https://www.sau.com.au/forums/topic/173816-new-qld-meet/
  • Replies 73
I am eager. I will be there for sure.
phil where the hell you been? good to see your still about......... look'in forward to another meet, if theres enough interest we pick a spot and have a bbq?..yeh weekend for sure.. what about redland bay area....suggestions?
https://www.sau.com.au/forums/topic/173816-new-qld-meet/#findComment-3194075
another option for a meet .....how about willowbank on a test and tune day......we all run the stags down the quarter....one on this wed, to short a notice tho.....maybe next month?
I'll be at the "Bank" on Wed. S13 and 180 are running. It will be a big day out.
Sorry to say but hope the rain stays away.
https://www.sau.com.au/forums/topic/173816-new-qld-meet/#findComment-3194432
:thumbsup:
Sorry been with out a computer for 5 wks looking at going b/band in the near future like next week or so. I'm always up for a cruise aspecially where stagea's are concerned.
https://www.sau.com.au/forums/topic/173816-new-qld-meet/#findComment-3194727
My car probably will not be going, but if you come to the Redland Bay area that is only a few minutes from house
Plenty of BBQ areas and parks on the water front
https://www.sau.com.au/forums/topic/173816-new-qld-meet/#findComment-3197233
That sound the goods Darrin. Not too far South and close for all.I am all for it.
https://www.sau.com.au/forums/topic/173816-new-qld-meet/#findComment-3199272
