Ah well, it's on ebay now: http://cgi.ebay.com.au/Nissan-import-HR31-...1QQcmdZViewItem
Time to move on.
says the man who had a similar painted 2door HR31 :)
lol @ you two. I'll never sell up... i couldnt afford to :)
I wanna see the new car soon!
LOL sky^rkt, moving to euro "goodness" but still going for jap power!
In terms of mods, probably a few simple things...dump and front pipe to make the exhaust 3" all the way, up the boost a tad and SAFC. 190 - 200rwkw should keep me happy for a while :dry:
awesome looking 34, where abouts u from?
I'm in the s.e 'burbs.
I'm pretty sure I've driven past your supra on Westall road before, that thing is mega low. :P
Recieved my SAU stickers in the mail yesterday, (thanks Kaz) so give us a wave if you see me on the road :D
Does anyone know where I can get the URL style stickers from? General meeting perhaps? I want one for the rear window...
Also I've purchased some speakers for the front doors and rear parcel shelf, is there a "how to" guide to remove the door trims on a GT-T? Is it easy enough to do? I tried a search, I came across a lot of useful information but not for the R34 ;)
Cheers
Anth
PS: Oh, and the 31 is still for sale for anyone interested:
http://cgi.ebay.com.au/Nissan-RB20-HR31-R3...1QQcmdZViewItem
Relisted on ebay, no reserve. It needs to sell on Sunday before dad throws it out of the garage :nyaanyaa:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
