I know the roll cage is probably the the single most expensive purchase to go racing, but after that it's all down hill....
Once the cage is in and you have the other safety items installed, you can go racing. To grater belief you don't need to have the car as fast as she can be or have new race rubber or the latest "go fast bits" ect..ect.. JUST GO RACING. Half the thrill is actually being out there and giving it a go. Learn the craft, become a better driver, have a s%#t load of fun and then... When time and budget permits, take the next step.
Life is too short! I have stuff all money to go racing, so does Briggsie, Perry, Maxfeild..... The list goes on. You simply don't need a V8 SUPERCAR budget to live the dream.
JUST DO IT! While you're still living and breathing.....
If only it was that simple though...
  • Replies 42
Posted Images
  • 3 weeks later...
I hope to run my Gtst next year. it's only got a new front mount, greddy plenum, power fc, 3inch exhaust and a roll cage. should there be anything else i should put in?
You will need an approved harness, window net, extinguisher, battery isolator with remote pull wire so it can be operated from outside the car,
race suit, plus your car will need to log booked with cams, plus a few other things CAMS website has a detailed list of requirements for circuit racing. For a good look in you could have a go at regularity, usually run by the MGCC at Symmons and the requirements are only same as running a club day I believe.
(Rocket_Rosco @ 3 Jul 2007, 06:37 PM)]
amen to that :sorcerer:
Well that means im only $14995 short :D
thats cheap, its cost me more than that for a dirty old pos hq, i wish i hadnt started hq, i would be in a skyline :rofl:
do you need a window net for TSS? I notice that not all of the cars had window nets last round.
Yeah you do a window net (only Historic Touring Cars are exempt, Targa class used to be but no longer), they cost a bit over 100 with quick release brackets if too lazy to make some up!
My cage for the RX7 will look like this. Allow $3500 + about $200 per bar extra. And thats the reduced price if you provide the car stripped and without glass fitted. Painting and padding is also extra.
Wheres the best place to get the net from stu?
Im not sure if any of you remember Leo's R33 GTR V-spec from up north, but the guy that built that is doing my cage. Stu, He's currenty putting the finishing touch's to his series 6 RX7 too.
Yeah I spoke to Spurry about mine, still debating if I want to drag it up and back on a trailer though!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
