hey guys I've been looking around a while for a front bar,
but I haven't found one that has a slot for fog lights :)
I mean I quite like the standard series II front bar
the thing is I installed the FMIC and cut a little too much off it.
So now am thinking bout a replacement but would like fog lights too.
Does anyone know of any?
Cheers.
https://www.sau.com.au/forums/topic/174233-front-bars-with-fog-lights/
Good luck finding another front bar. Next time around try not to cut into it (if that is possible) as it is illegal and could void your insurance! :thumbsup:
well you have to cut it if you've installed a FMIC, I've bought a front lip now.
so what bars can you get that would accommodate the FMIC without any modifications to it?
attached pics below.
Gold car is mine with Explosive kit on it. It's not very FMIC friendly though. THe fog light assembly sits lower than standard which makes it hit the cooler piping. I had to modify the back of the fog light assembly to make it fit. Still not perfect.
Blue car is a pic a grabbed off unique auto sports .com....
never heard of that before??
p.s. I have my old genuine front bar if your interested make an offer.
In melbourne. WIll need to be resprayed and has a small crack on one side :ninja:
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
