OH no my plenum
Sub Zero have helped me in the past so i hope they see you right.
A mates SR20DET powered Austin healy was killed by a transport
Co when being shipped to QLD for a rally(The bastards killed 2 new 540s and popped a head gasket doing burnouts)and Sub 0
fixed it for me fast. So their not bad.
Originally posted by KILLER-T
Steve if i can get my plenum back on in time is there any chance of getting my car on your dyno friday to check A/F mix.Then i can enter your dyno comp :jump:
KILLER-T
Hi mate, reading what has been happening, get back to me if you want to see if the one I have is any good or if you want a Plenum to run around on while waiting to get yours back from SUB-ZERO. Funny about the talk we had now when you come to think about it.
Chill dude
Danny
:uh-huh:
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
