  • Replies 951
AHAHAHAH Scotsman is here everyone hid
LOL. I'm just hangin' around seeing what crap you fools are talking up. *Runs and hides before flaming starts.
But seriously I was going to ask:- Is it easier for you guys just to fill out an entry form and do a deposit into the SAU-VIC bank account as per the entry form? Or are you going to get one person to collect money again... I think it would be easier for you guys and for me (And Mr. Tequila) if you all just did the entry form and payment yourselves ?? Thoughts?
That sounds easier if we deposit the money into the VIC account. Then you guys can chase it up instead of us :D
I have the week before off so Winton is an option. Would rather not drive down alone so assuming I can get at least a passenger I think I'd like to get down a day early and learn the track secrets of the Vic boys. If they get me running faster maybe I'll defect to Team Wang
I know this is still some time off but I vote for a very, very early morning start. If some of the guy/gals from north need a place to crash the night before, we have space.
I would prefer to pay into the SAU Vic account :D
1. Steve-O (N1GTR)
2. Ando (Boofhead.....oh sorry, A31Deviat)
3. Nick (INTUNE)
4. Victor (d00dz)
5. Chris (evil weevil)
6. Shawn (Fag) (Smoky)
7. Jessica (Sinful)
8. Andrew (nuttshunglow)
9. Anna (msnismo)
10. Corinne (D_I_F)
11. Brad (Risking - is that right?)
12. TJ (tjandriesen)
13. Sam (SAM916)
14. Jen (Tripin)
15.
Payment ($75) will be asked for in 3 weeks :D
Also, accomodation will be the same place as last time - so budget $40 per night (stupid bedpacks) and you should be right
Ok, whos in?
Count me in...Jen : )
Yep OK Done.
I will advise you guys in advance as to when I will be opening the event and accepting entry forms. Payment information and fax numbers will be on the entry form.
Will post the info in this thread.
Yep OK Done.
Thanks that would be great :D
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
