  • Replies 951
The good news is I'm staying up for the Sat night this time.
Good thing Snowy!!.. not like last time where you and James had to report to the ice cream truck!! :D someone call Mr. Whippy??!! :D
I will borrow one off Chubbs unless smokenhowzen has one.
Borrow what Andrew?? :D
ok i'm thinking about going down on the thursday to do winton on the friday and watch deca. if someone could pm me the details about accomidation etc that would be great
thanks mitch
1) I'm keen to get an early start on Thursday - like really, really early. I know a couple of you might need to drive down to Sydney and am happy for anyone to crash at my house Wednesday night if it helps.
2) There is a Shell near my house in Neutral Bay that sells Shell V Racing (100 Ron). If you really want that last little edge perhaps we can get gerry cans and see if we can get a few to travel down on Brad's trailer. I run it all the time and it is good stuff.
3) Having done this drive before, I know how nice it was to have a navigator/passeneger (The big A rode there and back with me - we both survived the experience). If anyone wants a ride down and back just to check it out, let me know.
thanks mitch
bump
so can anyone tell me? would really like to do this.
Guys...
Ok I am confused....
Is anyone heading down just on the friday?
Too spaced out to read other posts!!!
Otherwise the mrs and Iwill have a nice social drive ourselves!
Guys...
Yep. a few of us are....
Jess, Andrew, myself, ummmmm, Wayne, Kasey..... ummmm think there is more!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
