Hey Scott , im Chris i met you a couple of times, i had a 33 sedan.I think your best bet would to go a steam pipe custom manifold ( i had one on my car)The stainless ones seem to be weak, and doesnt last as long and other various reasons.And for your dump pipe same deal get who ever makes your manifold get them to make you a dump pipe depending on what turbo you are running.
Hey thanks for your reply Chris, your username is familiar but cant put a face to it. Been that long since ive driven the car (just got painted etc, been nearly year since its been out). Thanks for your input, steam pipe seems definately the way to go. What price you looking at for steam pipe? With the stainless are they all not worthy or is there some decent value for money ones?
Noticed you said had the sedan. Remember seeing it up for sale i believe, hope you got decent price!!!! Was very nice car, I am trying to sell my wifes 33 sedan but at the price they are going for, looks like its worth more to us to keep it!!
as was said before get a custom made one from steam pipe, the big issues with stainless is that all of the cheaper ones are made from thin steel which cracks, also the way a turbo works in regards to spool up is that it requires air flow and heat to make the turbo spin up, so you may find that with a stainless manifold you will loose soem response from the turbo as stainless is no good at retaining heat
yes it does happen.. my 180 has a SS bunch of bananas no cracking. it depends on what reinforcment has been welded onto the manifold. bracing is essential. also due to the thinner walls on SS it loses heat quicker than a cast or steam pipe. still good.. steam pipe is a good option mate.. but exy
My stock manifold is working well with my 3076R turbo
Bragging are we andy..??? lol
also in regards to dump pipes.. i like to use SS split dumps that preferable merge below at the elbow.. R334door im pretty sure u have one like that cause i was looking under ur car when doin ur FMIC and thought thats a neat bit of kit.
Yeah I love bragging its my style
Just saying that the stock manifold isnt as crap as every one thinks it is, I wouldnt bother changing it unless the turbo didnt physically fit anymore
And as Dano said look to HKS Cast or extrude honing (pending turbo size), both flow around 20% more than stock
haha i knw ur not bragging..
cast std manifold is good but they suffer from warping too..
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
