Hi, guys im farely new i do alot of research just want some opinions on my r33
im running stock R33 Gts-T Jap cat, 3inch cat back , Auto
Mods Done So far New Spark Plugs
3inch cat back, jap cat, and pod filter
i done the 2nd stage boost fix were i can get boost at 2.5krpm instead of 4.5k rpm full bost
Boost Sits just above the quarter line under the 7+ on stock gauge
i wann spend about 2k just to begin with
How much kw at wheels do i have ruffley with my mods
and how much rwk will i have with 2grand budget to begin with
https://www.sau.com.au/forums/topic/174643-new-r33-gts-t-95model-s15/
hey mate, i would say get a dump and front pipe along with a high flow cat to finish off the exhaust. You should see some good gains just from that. Up the boost a little to a safe level (a cheap bleed valve will do the job), you should also get a front mount at the same time. Also a computer would be good..something like an apexi power fc is out of your 2k budget so maybe an apexi afc neo would be good to do the fine tuning. :yes:
My car has the exact same mods as yours (compliance cat, 3 inch catback, highflow panel) and im making 148.5rwkw.
my next mod was gonna be a highflow cat + 3 inch front/dump pipe. complete your exhaust dood. its good for approx 15-20kw. approx a grand gone there
with the rest get that fmic and boost conrtoller and a good boost guage. up the boost to about 11psi (you'll already be running 9 once you put the fmic and full zorst on). $800 ish
you'll have 200 bux or thereabouts left from that. get a cold air intake box for your pod. atm you are gonna be making less power than my stock box with panel cos your pod is sucking hot engine bay air
i'd say once you're done with this lot you'd have about 170rwkw. keeping in mind that our cars lose power cos of the auto box thats a pretty good power value.
If you take the time to read the Forced Induction Guide
http://www.skylinesaustralia.com/forums/in...showtopic=66556
And mainly this thread entitiled, what mods to do first
http://www.skylinesaustralia.com/forums/in...showtopic=45218
It should put you well on your way
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
