Yes, you guys heard correctly. I know that everyone says r33 ecus are impossible to remap, but I have two of them right here.
I have for sale 2 remapped r33 ecus. As i'm sure you're all aware, when you up the boost on the stock ecu, timing is retarded severly, and the mixtures go really rich.
Both of the remapped ecus eliminate rich and retard. Ignition timing is advanced quite significantly throughout the rev range too, so they should make more power, more torque, be more responsive and have faster turbo spool.
I bought both of these ecus off the forums here, but I have had a change of plan for my car. They are both from famous japanese tuning companies. The ecus suit r33 rb25, with stock afm and stock injectors. Works to optimise the stock turbo, or aftermarket turbo (up to the power level that the stock injectors and afm support). Runs perfectly on 98 octane petrol (yes, they have been tested with a wideband air fuel ratio meter).
Price: 500 each TO YOUR DOOR via express post .
Contact: PM or call me on 0403 211 482 (Chris)
Edit: forgot to say, speed limiter has also been removed (of course :thumbsup: )
Edited by MANWHORE
https://www.sau.com.au/forums/topic/174728-r33-remapped-ecus/
lol... turbo tune on south road do a complete standard r33 ecu remap for $500. Everything you can tune a powerfc to do, they can do to the standard ecu. That price includes everything from A-Z in tuning a skyline.
Hey dude.. where are you located?
Also where did you get these from?
Am i able to test it before i purchase it?
Is it suitable for stock side mount? and then later suited for a fmic if i ever get one? or even a 34 side mount?
Currently just got full exhuast, pod, and little tad more boost..
Got any graph figures?
This ecu suited for a Series 2 manual?
If i do get this ecu, can a tuner be able to check it on dyno? and maybe even tune it a bit?
Or is the ROM untune able?
Got any pics?
Also if i sell this ecu, can i just put standard ecu back in without any problems?
cheers
edit: also how lean and rich is this ecu? if that makes sense?
Edited by siddr20
Hi sid
I'll try and answer all of your questions.
I'm located in st ives
The ecus are from japanese tuning companies (but works with 98 octane petrol fine)
of course you're able to test it first. I would prefer that you did - that way, we're all happy. I'm not here to sell stuff that isn't suited to people's car.
It most definitely is suited to the stock, fmic or 34 sidemount. Refer to my post above. Once you increase airflow to a certain level, car will go rich and retard. the map on my ecu doesn't do this. Even with the stock sidemount, it'll make more power, torque etc, because it has more timing everywhere
dyno graph is useless, because power is dependant on mods. I don't believe in dynos. I don't care about power figures. I much rather road testing with a wideband o2 sensor. Knock can be monitored by monitoring knock sensor voltage on a laptop
sII manual - haven't tested it on an sII manual. Worked perfectly on an sI manual.
You're most welcome to test it on a dyno. The ecu has a chip socket in it now, so if a tuner knows how to remap it again, sure, he can burn a chip and put it in.
You sure can - unplug it and plug the other one back in
yep. one was sold to me.
it seems like its normal from around idle - 3k rpm then its all smiles from then on. i felt a difference straight away.
and the fact that it can be re-tuned via a new chip (i didnt know that) is even better.
thanks mate. will keep you posted on my 1/4 times.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
