I have heard that Hallam Performance Exhausts are good, give them a call. Check www.yellowpages.com.au etc. You can get custom stuff made too of course.
Probably easier to get the one place to do it all. Unless you want a Jap brand exhaust, then it would be cheaper to source one s/hand and then have someone fit it. Check 4 sale section on here, I know a couple of melbourne guys were selling cat-backs fitting your description [CR34TION & ylwgtr2 I think].
https://www.sau.com.au/forums/topic/17475-exhaust-troubles/#findComment-361626
hey djr33, in my opinion I think its better for a workshop to do it, u get a reciept and if anything goes wrong they are liable for it.
My 32 came wit an exhaust although I got a high flowed cat installed at Casey Exhaust and I am very happy with their job and recomend them. I believe that they do Blitz exhaust's also. If you think of talking to them tell them Mark with the white r32 skyline reccomended you!
take it easy mate
:P
https://www.sau.com.au/forums/topic/17475-exhaust-troubles/#findComment-361635
Guest RedLineGTR
done my exhaust myself, the front pipe etc was done buy a shop because of of them dont line up. The cat Hi flow and the rest of the exhuast i done myself. High flow cat from one shop with flanges put on 3inch and the 3.5 inch cat back hks supper dragger was a heavy ****er but i got it done myself. I would be more than willing to help you out if you get like a jap exhaust, like a premade one. PM me if you need some help installing. Cheers Rob
https://www.sau.com.au/forums/topic/17475-exhaust-troubles/#findComment-361654
i put my titanium zorst on to day and couldnt get it lined up right at muffler,so it was hitting bumper couldnt resist and had to drive.when i get home ive burnt the shit out of my rear bar.bit upset but its sounds hella mad.my advice is workshop which is where mine will be going now :P
https://www.sau.com.au/forums/topic/17475-exhaust-troubles/#findComment-361681
Guest INASNT
How much did the titanium cost u?
https://www.sau.com.au/forums/topic/17475-exhaust-troubles/#findComment-362695
my trust exhaust took literally 10 mins to fit - all mounting posts etc fit perfectly... that is the advantage of jap stuff - you are guaranteed that it fits perfectly, doesn't rattle, scrape etc etc
BTW, DJ Lethal is selling an exhaust:
http://www.skylinesaustralia.com/forums/sh...&threadid=16212
https://www.sau.com.au/forums/topic/17475-exhaust-troubles/#findComment-363354
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
