Hey ppls,
Has any one bothered port matching the turbine inlet of their Garrett GT30/GT35 turbine housing?
Mine and another (GT35) the inlet is smaller than that of the stock exhaust manifold and another aftermarket manifold that used a 'standard' T3 flange size.
https://www.sau.com.au/forums/topic/174841-port-match-garrett-turbo/
Yep, my GT30R was exactly the same - quite a bit smaller.... I almost wondered if it was deliberate so instead of over shooting it'd undershoot the size of any manifold it was attaching to, and you could match it to suit from there.
Yes. ;)
Once I've got the head back from Miltons I will be bolting it on, welding up the inlet pipe and dump pipe as quick as possible. 3-4am late nights coming up. ;)
Just finished up port matching the std exh manifold; when I dropped the rb30det in I just wanted to get it in and started. :P
Ports 1 and 6 are out by 1.5mm towards the top of the port, 2-5 are fairly spot on.
See how I go tomorrow ripping in to it.
Nice - how is this coming along? Are you running one of the 56-trim GT3076Rs (with the anti-surge cover)? It'll be really interesting to see how you find it on the RB30.
Lithium.
I have the GT3076r .6 port shroud comp cover with the .82 IW rear. Should be good to see how it goes as I'm going to see what its got, then shove a little water/meth injection on it and see what I can really squeeze out of it.
Here's the before/after pic.
Its all smooth to feel even the stud lumps. The dremel is at the old mans so I tried my luck with supercheap drill stones; they worked quite well. :sleep:
I've since smoothed out the stud lumps even more so; the wastegate area was quite smooth so I didn't bother with that.
I'm waiting on a T3 spacer from MTQ; I got the head back last week so not long now. :O
Its all smooth to feel even the stud lumps. The dremel is at the old mans so I tried my luck with supercheap drill stones; they worked quite well. :D
I've since smoothed out the stud lumps even more so, the wastegate was quite smooth so I didn't bother with that.
Looking very nice. I have a friend who likes the way the GT3076R behaves on my RB25DET and wonders what it'd be like on a 3litre. Well we both do... as I'm yet to 100% decide what to do when I get to the rebuild stage.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
