HAHA point, car is not imac, most people are looking for a big hp gtr that is imaculate.
There are a few niggling little problems that I am unable to repair on the car before I sell it as I am very short of money.
Other than the paint, what things?
  • Replies 76
Posted Images
Dash vents, front cv boots not the cv's just the boots, speedo cable, front brake pads are getting low.
Thank you to everyone that has shown interest and offered swaps, although due to not being able to come to any agreements I will be forced to keep the car. It will remain for sale for the time being as I start to fix all the little problems.
The exhaust has just been repaired at castle Hill exhaust. A 3inch high flow stainless cat was installed and the wastegate was plumbed into the exhaust before the cat to make it nice and legal and much much quieter.
would you be interested in swapping with a white 97 rexy. basic mods ie pod exhaust intercooler struts bar sway bars sti wing bov and more. roughly 3 grand cash your way. rebuilt engine 30000kms ago with receipts. if so let me know and ill send you more info and pics.
thanks jason
thanks jason
Sounds good, send me some pics.
By the way to anyone who is interested I can get a pink slip no probs for the car as it is legal.
