Tried a search and all i can come up with is the sizes that people fit...
I have an R34 GTT.
I know they come with 17x7.5
What is the PCD on this model?
And what offset are the stock wheels and what can i fit up to?
I might get some deep dish if i can (not going to fit spacers...and do not want to make the rims stick out)
And also, what is the point in having wider rims at the back?
Just better grip?
Thx in advance~
https://www.sau.com.au/forums/topic/174937-what-offset-and-size-can-i-fit/
I have an R34 GTT.
Just better grip?
Thx in advance~
I hope this helps?
PCD: 5 x 114.3
Standard R34 GT-T: offset +35 Size:17 x 7.5
IMO I have seen lots of 34's usually running the following:
Front: 17 x 8 +30 - +36 will sit just inside the guards nicely
Rear: 17 x 9 +32 - +38 will also fill the guards nicely
And the same can be repeated in 18's aswell without any problem :thumbsup:
As far as if staggering wheel size providing more grip, for the most part it will have to do with the choice of tyre you use..
Phill
18x8.5 front 18x9.5 rear is max. More rear grip from bigger rear tyres. This makes you more aware of the lack of front end grip. The R34 has quite neutral steering and you are messing with this but you kind of do anyway when you increase the power.
That's generally true, but it also depends on where the face of the wheel sits. Often you will find front wheels will have the face sit out further for brake clearance. All things the same though (same wheel, same face position, same width), lower offset will mean more dish.
can i fit 18x9 with an offset of 30 on all four corners?
and can someone correct me if i'm wrong, but i believe the lower the offset, the more dish you have???
18 x 9 +30 would have the looks, but you'd definitely have to under tyre the front and/or roll your front guards :P
I currently run a 17 x 9 +20 all round on my R33 with only 235/45's and I have to roll all the guards, but as you can see I do have almost maximum dish ;)
Thats definitely true, as I have especially gone for a set of rims that were off a GTR or Z32 for maximum brake clearance or yo can custom order rims depending on application for extra $$$.
phillb
how the hell did you fit +20 offset on your car?
Are R32's different offsets to R34?
With tender care :P Thats my car black four door, though I'm on the hunt for a guard roller as even with stretched rubber they do rub a little. IMO I think it just helps to improve the look of car as I've never been a fan of the sunken look!
From what I've read all GTR's from factory are:
R32 GTR = 16 x 8 +30
R33 GTR = 17 x 9 +30
R34 GTR = 18 x 9 +30
Though R33 and R34's do have apparently more guard space and can fit even lower than +30> and still have no problems with clearance..
I haven't ever tried my rims on a 34 I am sure you will have a similar situation to me and also have the same width all round you may find a small amount of tramlining if you have the same size tyres. though that can be cured with wheel alignment and or run 225/235 front and 235/255 rear depending on the style your after?
Cheers
Phill
Edited by phillb
this is beginning to gimme a headache
so much info on GTR's yet not that much info on the rwd variants :P
the standard R34 GTT come with 17x7.5 with a +35 offset i think...
GAHHH~~~
mayb i'll get 18x8.5 fronts with a +30 offset and rears 18x9 with +30 offset..
GAHHH~~~
And I think you'll be fine they should sit nice and flush and you shouldn't have any guard clearance issues.
If you want to see 9" wheels on a gt-t just pm me and you can test fit mine?
Ill give you the short answer..
18X9.5 rear with +38 offset ... Yes you could also run 37 or 39 but 38 is right on the guard with 9.5" rim
Fronts I run 18x8.5 with +32 offset .. Yes people like to pump it out more but I picked such a lower offset because the stones and crap fly up the side of my black paint work when u turn ..
Edited by DECIM8
That would be pretty spot on. I ran 18x8.5 +30 and 18x9.5 +38 before and they were perfect. A bit of inner scrub on full lock on the drivers side inner plastic guard, I can live with tht...no rolling or lipping required.
Currently running 18x8.5 +35 and 18x9.5 +35 no guard mods needed.
  • 7 months later...
Hi guys just need some help while on this topic.
Ill looking at buying 18inch wheels with 18x8.5+43 Rears 235x40 & 18x8+41 Fronts 225x40.
Will these offset fit my R34 gtt?
Would it clear the brakes?
Thanks guys
Yeah i might need a hand as well. I have some drift teks, 17 x 9.5, not sure what offset they are. Ive been told they will sit pretty much flush with the guards on my 34 GT-T with no rubbing?
Edited by Damo_R34
  • 4 months later...
Guest TR34GT
Guys,
I remember reading a past issue of High Performance Imports magazine about 3 years ago, when they were helpfull enough to list the full range of original and possible fitments of R32, R33 and R34 cars including GT, GTR, GTST and GTT.
I can remember one thing about that article.
R33's can fit a whole lot more rubber under the guards, if the guards are in the original state.
They listed 18 x 8 front and 18 x 9 rear, as the best possible fitment to use.
I've used 18 x 8.5 front and 18 x 9.5 rear before with 265s (rear) on an anniversary R33 I used to own, and the tyres wore away part of the Bilstein shocks upper flange on both sides. (scary that I didn't notice till almost too late)
The R34's optimum setup was supposed to be 18 x 8 front and 18 x 8.5 rear.
225's and 245s fitted?
If the car's lowered, forget all of the above!
Jim (TR34GT)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
