D-limo Posted July 2, 2007 Share Posted July 2, 2007 Ok I have searched. Pretty definitate on the rear GTR bar fitting. Can anyone confirm without a doubt a front R32/R33 GTR front swaybar will fit on the front of an A31/C33? Is it better to use the stock GTR end links? Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/ Share on other sites More sharing options...
daisu Posted July 2, 2007 Share Posted July 2, 2007 I'm pretty sure the Skyline front sway bar is different, because cefiros use S13 front suspension. Whiteline makes swaybars specifically for cefiros (different to S13) because of the increased weight. Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3208648 Share on other sites More sharing options...
Simon-S14 Posted July 2, 2007 Share Posted July 2, 2007 it fits, my ceffy had GTR bars all round Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3209572 Share on other sites More sharing options...
Ceffy_SA Posted July 3, 2007 Share Posted July 3, 2007 I have GTR rear sway bar and Whiteline Adj 27mm front sway bar for a R32 GTS-T, great mod for the A31, driving the car through the hills was alot more fun than with the stock sway bars Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3210073 Share on other sites More sharing options...
daisu Posted July 3, 2007 Share Posted July 3, 2007 (edited) Fair enough, well I'll be comparing size of my spare GTST front swaybar with the factory sway bar on the ceff tomorrow, possible upgrade. Edited July 3, 2007 by daisu Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3211302 Share on other sites More sharing options...
salad Posted July 3, 2007 Share Posted July 3, 2007 I have GTR rear sway bar and Whiteline Adj 27mm front sway bar for a R32 GTS-T, great mod for the A31, driving the car through the hills was alot more fun than with the stock sway bars How does the front R32 GTS-t bar fit? Mainly interested in linkpin angles. I was under the impression that the lever "arms" were too long for A31s with the R32 swaybars. Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3211540 Share on other sites More sharing options...
Ceffy_SA Posted July 4, 2007 Share Posted July 4, 2007 (edited) Hmm thats interesting, mine went in pretty much fine, maybe its not a skyline one after all, i didnt seem to have any trouble fitting the link pins in at all, sway bar has been removed now due to the engine comming out ill have to take some pics when i get the car back on the road again. Edited July 4, 2007 by Ceffy_SA Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3211834 Share on other sites More sharing options...
carter Posted July 15, 2007 Share Posted July 15, 2007 ive got the whiteline blade adjustable gtr swaybars on mine n they fit fine both front n rear, Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3230354 Share on other sites More sharing options...
dangerous_daveo Posted July 15, 2007 Share Posted July 15, 2007 I though it was worked out a while ago that the stock gtr sway bar option was almost a waste of money because it really wasnt that much bigger or better than a stock bar. Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3230551 Share on other sites More sharing options...
carter Posted July 15, 2007 Share Posted July 15, 2007 (edited) yea tru that, itd would b a better option 2 go whiteline adjustable 1s i reckon Edited July 15, 2007 by carter Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3230803 Share on other sites More sharing options...
salad Posted July 16, 2007 Share Posted July 16, 2007 I though it was worked out a while ago that the stock gtr sway bar option was almost a waste of money because it really wasnt that much bigger or better than a stock bar. Wouldn't be surprised at all if the GTR front bar was the same size, it's effectively about twice as stiff on the GTR as it bolts to the upright instead of halfway along the LCA like on the ceffy. On the rear the GTR bar (25mm hollow) is about twice the stiffness of the stock ceffy bar (16mm solid). Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3231237 Share on other sites More sharing options...
Wishin Posted October 25, 2007 Share Posted October 25, 2007 Is this problem solved then? I'm looking to buy a front swaybar for my Ceffy. From what has been stated above it looks like I should be using a GTR front sway bar from Whiteline?? Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3434043 Share on other sites More sharing options...
meanman Posted October 26, 2007 Share Posted October 26, 2007 PM Sydneykid on the forums here, he will fat you up with swaybars specifically designed for the Cefiro. Fully adjustable front and rear, brand new - $219 each. I believe he or someone he knows owns the design and then they get whiteline to manufacture it. Thats why you cant go directly to whiteline coz there is no part number for it. Go see Sydneykid and he will get them made for you. And if any of yous have read the suspension part of the forums, you will know Sydneykid knows his stuff, known to pretty much make the best suspension kits for Skylines/Silvias/Cefiros Link to comment https://www.sau.com.au/forums/topic/174998-gtr-swaybars/#findComment-3436482 Share on other sites More sharing options...
