Ando you want to be like me dont you ?
What 1:18 in a 33GTR................ :sick:
I'll take my 1:13 in a taxi my good friend :sorcerer: :)
AHAHAH lol, but yes in seriousness, i want more grip and power!
Sign up mofo!
  • Replies 107
you will be heaps quicker ando. if you are doing 1:13s at wakefiel, but doing 1:58s at EC either you really love wakefield, or you were getting held back badly with the limiter at EC. 1:13s at wakefield should put you at around a 1:55 or lower at EC. :dry:
you will be heaps quicker ando. if you are doing 1:13s at wakefiel, but doing 1:58s at EC either you really love wakefield, or you were getting held back badly with the limiter. 1:13s at wakefield should put you at around a 1:55 or lower at EC. :rant:
But that doesn't take into account his experiance at either track.
Wheels magazine (May 1991) Kevin Bartlett, in the stock GTR with street rubber rattled off a 1:56sec lap at EC. Just goes to show you what a good driving can do!!!!
you will be heaps quicker ando. if you are doing 1:13s at wakefiel, but doing 1:58s at EC either you really love wakefield, or you were getting held back badly with the limiter at EC. 1:13s at wakefield should put you at around a 1:55 or lower at EC. :rant:
1:13 was my second attempt @ Wakefield and doesnt have the long arse straight like E/C...
1:58 was 1st attempt with the car hitting speed delimiter before the pit entrence down the straight.. so plodding along the straight @ 170km/h would of been costing me a couple of secs me thinks...
All things going well, 2nd time round and speed delimiter removed i am hoping to hit 1:55's or lower....:(
Can't wait!
Proably not of as much interest on a Nissan-oriented forum, but the founder of Spoon Sports will be there, to celebrate their new partnership with Pro Concept.
Edited by scathing
wow... i'm really happy for joshua. i've been going to him since 01, very ealry stage of pro concept..... good old days where you could spend the whole day inside the workshop getting ur car serviced.. going through nismo catalogue, hyper rev mags and talking/smoking with josh :laughing-smiley-014:
hehehehe.... you still can if you don't mind him rushing off mid convo :) or answering a call or having another customer come in.. :D
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
