Guest F U Z
Hi everyone,
I wasn't sure if this is the place to post a for sale... mods feel free to move to an appropriate place:)
Basically, we have a near new Power FC with hand controller in the original box's for sale.
$1600 firm.
The package is already excellently prepared for COD, so interstate buyers welcomed. We are located in WA.
Able to be shipped immediately.
MUST SELL.
F U Z
Guest F U Z
1550? We are on a cost re-coupe mission. It was bought new and is in mint condition.
I've had several almost sells COD, but after the last guy pulled out at the last minute, i must admit that i am losing confidence in the COD form of sale.
It's a good buy. No hassles with dodgey sales.
F U Z
Guest F U Z
$1200 is the current offer.
I'd like to not have to un-package the ready for COD parcel, but it will end up being for WA only buyers in a show room...
This is a short time only sale. If you want it, a good offer close to my reserve will take it. Otherwise, we are not going to give it away...
F U Z
Guest F U Z
Thanks everyone...
The Unit is now -: SOLD :-
Cheers.
Originally posted by JiMb0
Is this a business or personal sale ? From your last comment Fuz it sounds like a business to me. Unless you were reffering to your lounge room as a "show room" ?
(I am not a business, but have connections for where i would have placed it in their showroom display cabinet for sale. We still had the original boxes and so thought we may have had more luck trying to sell it there.)
F U Z :(
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
